588,555 active members*
4,802 visitors online*
Results 1 to 6 of 6
    Sep 2004
    51
    Yasnac 2000b Parameters Mori Seiki
    I need help with several problems with my Mori Seiki SL-1 with Yasnac 2000b control. The control has failed yet another time. This time it will not accept programs via the BTR and results in an alarm 14 - illegal G code. I can enter from MDI but G96 and G97 will not go into memory. I am trying to do a reset of memory and parameters. Then on to investigating the boards. The battery is fine and the parameters from 71-98 are ok.
    1.) Do any of you have parameters from 1-70? Mine are all blank and I think a Yaskawa tech told me that I will only have 71-99. If you do can you tell me what your settings are?
    2.)Do you have to put the system rotary switch to 5 during entry of parameters below 70? My book says enter parameters with switch on 1 but the book is for 2000G and Yaskawa tech says 5.
    3.) What do you have entered for parameter 99?
    Thanks!
    Sep 2011
    change parameter -x on mori yasanac
    need help
    Feb 2009
    6028
    Quote Originally Posted by cardenas770 View Post
    need help
    Not just a parameter. You will need to do a few wiring changes. I know I have the how to at home somewhere, not sure if i have one that old though.
    Sep 2011
    I have a parameter list for 2000g Control. Not sure if this is compatable with 2000b or not. If you want it let me know and I'll get it for you.
    Sep 2004
    51
    Quote Originally Posted by GetMfg View Post
    Thanks for the consideration but I have torn down the control and am in the retrofit process. I am using a PLC from Automation Direct and a new control from Mach Motion with Mach 3. A lot of learning going on...
    Keith
    Jul 2009
    80
    What are you going to do with old stuff?
    Robby
  1. Mori Seiki SL2 With YASNAC
    By Antonio Arguijo in forum Mori Seiki Mills
    Last Post: 05-19-2019, 11:12 PM
  2. Mori Seiki MV45 Yasnac MX1 Help Please
    By premier_industr in forum G-Code Programing
    Last Post: 10-21-2011, 10:59 AM
  3. MORI SL-3A YASNAC 2000B CONTROL
    By JY`S MACHINE in forum Mori Seiki lathes
    Last Post: 05-04-2010, 04:09 PM
  4. Mori Seiki MV45 Yasnac MX1 Help Please
    By premier_industr in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-05-2008, 04:14 PM
  5. Mori Seiki MV45 Yasnac MX1 Help Please
    By premier_industr in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 01-27-2007, 06:04 AM
