587,770 active members*
3,307 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Mill won't run... fault light on...
Results 1 to 9 of 9
Hybrid View
    Jan 2009
    402
    Due to many circumstances... some foreseen and others not.... my Grizzly X3 mill has sat idle since it's arrival last March. It's been in my dry basement waiting for me.
    Finally, tonight I fire it up to do the spindle break in routine called for in the owners manual....
    Fault light... mill won't run!
    I pull the fuse and check it with a multi meter, and it's good.
    After a few times removing and re-installing the fuse, the fault light goes out and the power light comes on. So I start the mill and run the mill in low range at slow, med. and fast speeds. I turn the power switch off and change the gearbox to High range and get the fault light again when I turn it back on.
    Now I can't get the fault light to clear after several attempts with the fuse (which is still showing continuity with the multi-meter).
    Ughhhhh! Not what I was looking forward to. And now the mill is beyond it's one year warrantee period.
    Any recommendations?
    Feb 2009
    137
    Most likely the e-stop button
    Check the e-stop circuit. An easy test is to just jumper it out at the board.
    Jul 2008
    922
    if it is the board, i switched to another motor and have all my x3's electronics in the corner of my garage
    Nov 2009
    724
    Lets start simple here first order of business is the typical tug test you would be surprised how far a screw can turn on that sloooow boat from china
    I checked my wiring before I started and had probably 50% of the connections loose even a wire completely out of the terminal
    May 2004
    35
    Matt,
    The X3 controls require the speed switch to be set to "0" when the forward/reverse switch is moved to the run position. If this switch is not full "0" you will get a fault light. If you are following Grizzly Break-In proceedure, I believe this is not clearly stated and may instruct you to switch on improperly.
    Have a good day,
    Jimbo7
    Jan 2009
    402
    thanks for the replies guys....
    I have some good leads for my trouble shooting...
    full zero on the speed selector then cycle forward reverse switch....
    Check connections on e-stop and then general inspection and snugging up connectors on the board and collumn switches.
    Not real impressed with the mills torque, as I could slow the motor by squeezing the spindle with my right hand at just about every low range speed setting.
    Oh well.... at least I'm making 'some' progress with the conversion gig again, even if it is two steps forward, one step back.
    Jan 2009
    402
    back up and running
    Pulled all the covers and tightened all the block terminals, checked all the solder joints and wiggled all the connectors...
    All to no avail...
    Then I fiddled around with the fuse holder and Bingo!
    Don't know what exactly I did.... but I got through the run in procedure and experimented some more without any more problems.
    May 2009
    Hi Matt,
    I had exactly this problem last year: got an X3 from Axminster, finally got around to unpacking it 6 months later (other stuff to do), didn't work. Eventually, after a swapout pcb trial from Axminster, it turned out that the microswitch on the safety screen (the little perspex door) was only just not being actuated when the screen was in place. Like a lot of probs it was obvious only when discovered, IYSWIM.
    John
    Jan 2009
    402
    that's interesting....
    I have the Grizzly version though and don't believe it has such a safety screen with the switch controlled interlock, though I could certainly be wrong.
    I have my mill up and running now and am having a ball and learning a ton manual milling machine conversion parts.
    I read through a CNC routing guide published by Onsrud and am putting a lot of that info. into practice, both on my X3 and at work. I actually understand chip rate now. I increased the feed rate by a factor of four on our old dog router and am seeing much less bit burning, while making very minor sacrifices in cut quality.
  1. Red FAULT light on Gecko 320
    By schwinndk in forum Automation Technology Products
    Last Post: 09-21-2009, 07:33 AM
  2. Gecko 320 FAULT light is on
    By schwinndk in forum Gecko Drives
    Last Post: 08-14-2009, 03:22 PM
  3. G540 Fault light
    By cnccustom in forum Gecko Drives
    Last Post: 01-06-2009, 07:53 AM
  4. 320 fault Light
    By Ed Williams in forum Gecko Drives
    Last Post: 02-06-2008, 04:28 AM
  5. G320 Fault light doesn't turn off
    By lamote in forum Gecko Drives
    Last Post: 04-11-2005, 10:39 AM
