586,111 active members*
3,645 visitors online*
    May 2010
    Thread Milling
    I've been threadmilling for a long time but it's such a slow process. I'm looking to speed up my cycle times and I'm looking for general tips/tricks to get the most out of this process.
    Any advice on?
    1) program style
    2) recomended brand of threadmills
    3) # of passes, rough/finish spring
    4) climp/conventional
    Thanks in advance.
    Kdog
    May 2008
    152
    Are you using single or multi-point thread mills?
    May 2010
    Multi point indexables and helical solid. I just looked at an Emuge single but I've never tried it.
    May 2010
    Results
    After doing several trials with different tools etc I'd like to post the results for anyone who's interested.
    As far as cycle time goes I haven't made much of a dent. Surface finish is a concern in my case so it's limiting. Best results came from helical multi flute solid threadmills, I haven't found much difference between suppliers. I use a rough climb at about 2x feed, then, climb finish with no material left on between the two. Just pass back over in the opposite direction. I found a surprising amount of tool deflection so the finish pass gives better finish as well as dimensional consistency. This method likely reduces my tool life but I'm cutting brass so it's not really a concern.
    Hope this helps for anyone who's looking.
    May 2008
    152
    Cool. I'm getting ready to do my first thread milling...maybe this weekend.
  1. thread milling
    By turbothis in forum Dolphin CAD/CAM
    Last Post: 11-12-2009, 05:58 AM
  2. Thread Milling
    By speedtwin69 in forum Haas Visual Quick Code
    Last Post: 11-02-2009, 02:01 PM
  3. NPT thread milling
    By MechMach in forum Visual Mill
    Last Post: 02-13-2009, 01:31 PM
  4. Thread milling
    By TT350 in forum Tormach Personal CNC Mill
    Last Post: 12-01-2007, 04:01 AM
  5. Thread Milling 3/8-18 NPT
    By shawn in forum G-Code Programing
    Last Post: 08-26-2006, 02:24 PM
