603,893 active members*
3,935 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > error message OKUMA
    May 2010
    error message OKUMA
    When trying to retrieve a program from the TC Index I get error 102.21.255.129 or 102.11.255.129. Have checked the settings on the controller and PC. Can ping IP adress but not transfer. Please help ---What am I doing wrong
    Mar 2009
    1992
    are You using "third party" ftp server on PC? Check settings. In case You have Windows, maybe some update messed up access rights?
    May 2010
    check IP address on the mc and PC,mybe some configuration setting has change.IP address in mc canot same with PC right?
    check also baut rate, ok!
    regards,
    stupidboy
  1. Okuma LB15 with 5000L error message
    By stude8 in forum Okuma
    Last Post: 07-25-2019, 02:48 PM
  2. error message
    By Claude Boudreau in forum BobCad-Cam
    Last Post: 08-13-2011, 11:39 AM
  3. Error message CR1 etc.
    By NPI in forum Bridgeport / Hardinge Mills
    Last Post: 09-25-2010, 03:34 AM
  4. How do I fix this error message?
    By Patt66 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-09-2010, 07:22 PM
  5. G83 error message
    By HBFixedGear in forum Fadal
    Last Post: 01-30-2007, 04:42 PM
