603,344 active members*
3,607 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > Bridgeport / Romi Lathes > Help needed with lathe romi ez path emergency stop
    May 2010
    Hello,
    I'm having trouble with my bridgeport ez-path series 1 lathe.
    The emergency stop error message keeps flashing up on the screen, with hit (key) to clear. And wont clear.
    I can bypass this message by manually pushing the button in on the 24v relay and then the message clears. hovever,, when you go to home the machine the slideway comes past the limit switch then comes back. Then the screen will come up with.... following error limit exceeded.
    The bmdc card is comunicating with the auf board and all the drives work manually. Its just strange why the relay wont come on on its own.
    any help would be great.
    thanks
    Dave
    Nov 2004
    3028
    This machine has 2 E-stop switches. One on the CRT pendent and one on the carraige. the one on the carraige suffers from coolant contamination. The box the E-stop switch is in has a connector on the back. Check it for corrosion. Then there is the possibility that the cable coming from the control through the flexible wireway to the carraige can break from flexing and age.
    George
  1. Bridgeport/ROMI EZ Path Lathe
    By mcsf in forum Uncategorised MetalWorking Machines
    Last Post: 11-28-2012, 12:39 AM
  2. Bridgeport EZ path romi lathe
    By dipiazza in forum Uncategorised MetalWorking Machines
    Last Post: 12-05-2008, 04:48 AM
  3. Need HELP on Bridgeport EZ-Path ROMI Lathe
    By Michael Esch in forum DNC Problems and Solutions
    Last Post: 04-10-2007, 04:38 AM
  4. Romi EZ Path Lathe
    By kenski in forum Uncategorised MetalWorking Machines
    Last Post: 07-22-2006, 03:25 AM
  5. Manual needed to Romi/Bridgeport CNC lathe
    By mgreene in forum Bridgeport / Hardinge Mills
    Last Post: 02-15-2005, 09:20 PM
