603,923 active members*
2,785 visitors online*
Results 1 to 6 of 6
    Apr 2010
    486
    Automatic oiler question
    Recently bought a Bridgeport Series 1 CNC machine. I'm removing all the old computer setup and installing a PC, Geckos, etc.
    I understand the automatic oiler is supposed to supply a shot of oil once in a while.
    How does this work? Do I simply supply power to the oiler anytime the spindle is running and it supplies the timing? Or is there a timer circuit inside the computer somewhere? Or does a Leprechaun come in and activate the oiler? Or what.
    Tom
    Nov 2004
    3028
    This oiler has a cam that lifts a plunger and then it drops. It typically is ON when the spindle is on.
    George
    Apr 2010
    486
    Thanks, George.
    Nov 2009
    4415
    Is it a Bijur? Some have a cyclical timer that say turns it on every 6 minutes (it is adjustable) and the volume is variable also.
    Feb 2009
    9
    I have a ez-path SD II and on the side I have the bijur pump. How can I adjust how often the oil gets shot, I been noticing that the ways don't seem to get much oil on them.
    thanks,
    art
    Nov 2009
    4415
    This might help.http://www.youtube.com/user/BijurDelimon
    However I believe there is a silver knob on the top. It controls the cc per pump. I think there are 5 videos in their link. I know 1 gives a pretty good explanation of its operation and maintenance.
  1. Automatic Oiler vs Manual Oiler
    By bruce34rr in forum Tormach Personal CNC Mill
    Last Post: 05-19-2010, 04:21 AM
  2. BIJUR OILER
    By tpmx57 in forum Bridgeport / Hardinge Mills
    Last Post: 06-08-2008, 10:33 AM
  3. Button Oiler - How to use.
    By Eric Q. in forum Shopmaster/Shoptask
    Last Post: 03-15-2008, 05:40 AM
  4. Semi-automatic oiler
    By ozzie34231 in forum MetalWork Discussion
    Last Post: 02-18-2006, 07:29 PM
  5. Timer / oiler question
    By chrispy in forum Mach Software (ArtSoft software)
    Last Post: 08-21-2005, 03:36 PM
