603,546 active members*
3,180 visitors online*
IndustryArena Forum > OpenSource CNC Design Center > OpenSource Software > PartKAM - free crossplatform 2.5d CAM
Page 2 of 7 1234
Results 21 to 40 of 138
  1. #21
    Jan 2008
    853
    This is nice Jack!
    I just made a simple circular pocket, dragged it and it seemed to jump half-way back. When I generated a toolpath, the path in the circle was at the dragged-to spot, but the circular outline was at the jumped to point. I didn't check the gcode to see which was real.
    Cheers!
  2. #22
    Oct 2008
    242
    ah, yes I have seen this before. It's just a delay in the rendering, if you do a zoom or a pan it will update to the new position. I will be fixing this issue in the next release.
    thanks for the report! :]
    ___________________________
    http://jack.works
  3. #23
    Oct 2008
    242
    hi guys
    I've just finished implementing a new feature: true shape nesting! As usual, please report any bugs if you see them.
    check it out at the same url: www.carveit.ca/partkam
    I'm not sure how the efficiency compares to commercial products, but the results look pretty good to me :rainfro:
    I've attached a demo file if you want to try it out.
    here's some instructions:
    Attached Files Attached Files
    http://jack.works
  4. #24
    Apr 2006
    3498
    Amazing
    Thanks for sharing..This is first programmer who put his software at its extreme at CNCZONE..
    http://free3dscans.blogspot.com/ http://my-woodcarving.blogspot.com/
    http://my-diysolarwind.blogspot.com/
  5. #25
    Apr 2008
    1577
    Amazing is a good word. One of the most impressive free CAD/CAM attempts I have seen in a long while. Great work!
  6. #26
    Oct 2008
    242
    hold the applause, I've got more cool stuff in the works : ]
    just gotta finish drilling and tabs, then the essentials will be all there.
    http://jack.works
  7. #27
    Apr 2006
    3498
    Quote Originally Posted by Jack000 View Post
    Wow.. Your programming skills are amazing.. but i would like to make the GUI in Visual Basic etc... Just see my very simple program on embroidery machine Gcode Generator.. the program is very simple and the person like me can program it..
    www.my-woodcarving.blogspot.com
    However, I am really impress by your programming skills.. Wish you make it 3D and in 3D you involve the latest tool path as the VOLUMILL are using
  8. #28
    Oct 2008
    242
    wow that embroidery program looks amazing. If I only had a sewing cnc :rainfro:
    I'm not planning to do 3d in the immediate future - I would have to port the whole thing to an offline program. I'll probably wind up doing it at some point, but not for a while.
    http://jack.works
  9. #29
    Hey. Anything new on PartKAM these days? I've been trying to use it for a project I'm working on, and I keep getting the "The Adobe Flash Plugin has crashed" message after it sits there thinking for a while. I've got some islands nested inside of several closed paths, trying to do some 2.5D "relief" type stuff. There's a raised border, then a milled pocket with a bunch of islands in it. The "pocket" operation works fine, and correctly identifies the raised border and the islands, but when I tell it to generate the tool path, it goes off into the weeds and eventually gives me that "crashed" message. Any updates or ideas would be very much appreciated. Still going to release this as open-source? I share a workshop with an excellent programmer (ahem)Chris Radek(ahem) who I might be able to persuade to work on it a bit if we had the code... XD
  10. #30
    Oct 2008
    242
    can you save the problematic file (as svg) and upload it here? I haven't seen it crash before.. even if an error occurs it should give you an opportunity to cancel out. Also, does this happen when you click "calculate toolpaths" or "export gcode"?
    I should have a better idea of what's wrong after seeing the file. Could you also post your browser and flash version? Flash 9 is sometimes incompatible with flash 10.
    I am planning to make it open source, maybe some time in october - I'm working on another secret project that uses the partkam app, and I'd like to release both at the same time. :]
    anyways, it's good to see that people actually use this thing :rainfro:
    http://jack.works
  11. #31
    I've attached a screen shot of PartKAM running the part. It actually gets to 100% and then sits there for quiet a while before the Flash plugin crashes. I can hit "cance(l)" and it will stop, but it doesn't produce any output then. I'm really not at liberty to give away the source file to the general public, so I'll see if I can e-mail it to you directly, if that's okay. Thanks!
    -Bill
    Attached Thumbnails Attached Thumbnails Screenshot-PartKAM - Mozilla Firefox-1.jpg
  12. #32
    Oct 2008
    242
    here's a development "branch" that I've created with the fix: www.carveit.ca/partkam/development.swf
    I've noticed that it runs faster if you download the swf and run it standalone instead of in your browser.
    let me know how it works for you!
    http://jack.works
  13. #33
    Talking
    That seems to have done the trick. Thanks so much! :cheers: I downloaded it, but I have to open it in FireFox, because I don't think there's a way to directly execute Flash code under Linux, but it still works fine. This is going to be of tremendous use to me, I'm sure!
    A couple of questions:
    Is there any way to save defaults for various operations (e.g. depth per pass, tool size, etc.) in a file so you don't have to enter them every time?
    I don't know if I'm doing something wrong, or if these are bugs (or maybe incompatibilities between versions of Flash?) but "Undo" never seems to do anything. I'm forever accidentally grabbing part of a path and dragging it out of shape when I'm trying to move it. If I click "undo" nothing happens.
    Also, deleting toolpaths doesn't seem to work consistently. Sometimes, if I just hover the mouse over a path's name in the list and wait until it highlights with the blue background, I can hit "Delete" and it goes away, but most of the time nothing happens. I can't really "select" the path, because if I click on it, I get the parameter window for that path. (Maybe you could put a "Delete this toolpath" button at the bottom of that window?)
    This is a really, really useful tool for those of us who can't shell out hundreds or thousands of dollars for commercial CAM software. I'm anxious to see what your new "secret project" is... :-)
  14. #34
    Oct 2008
    242
    hmm... undo should with deletes, path-moves, and point-moves. Try deleting something and then undo, does it come back? Also, I haven't implemented ctrl-z, you have to go to the menu and click "undo". If that doesn't work it'll be very strange indeed.. I may have to experiment with the different flash versions.
    to avoid dragging a point, just select everything (paths will turn red) - click and drag with the select tool to select multiple paths. Selected paths can't be dragged out of shape.
    to delete a toolpath, just select it and press delete. To select it just click and drag with the select tool. A selected toolpath that has not been calculated will turn blue, and a calculated toolpath will simply be bolded.
    as for saving defaults, I think that will be implemented when my other project is done. Flash doesn't allow you to access local files, so making defaults persist across multiple sessions is difficult. I'm making a server-side component so you can create an account and save your defaults and such on the server.
    http://jack.works
  15. #35
    I've been using the development version, and suddenly it's decided it doesn't want to save g-code. Not sure what's going on or when it changed, but I'm pretty sure I was able to a few days ago, and now I can create a toolpath and calculate it, but when I click "export gcode" I just get a blank stare. Sometimes it comes up and prompts me for a filename, but 99% of the time it just sits there with the menu selection highlighted and doesn't do anything. I can go click on other menu options after that, so it's not completely hung; it just seems to be ignoring the save button. Help!?!?
  16. #36
    Oct 2008
    242
    does this happen reliably with certain toolpaths, or is it random? I uploaded a new development version (you may have to refresh the page) - there's no fundamental difference in how it works, but let me know if anything changes.
    http://jack.works
  17. #37
    Oct 2010
    Hi Jack and major kudos on the CAM Program here!!! :rainfro: I hope this is a simple question: Is there a method of reversing the tool path direction on a profile operation??? the toolpath generated on my project cuts to the left of the vector, and i always like to "climb cut", or be on the right side of the vector when profiling.
    Thanks much, Bill
  18. #38
    Oct 2008
    242
    that shouldn't be too hard to add, just need to reverse the direction of the curve. I'm working on another project right now but I should be able to fit it into the next release.
    Also, I think it's about time I released the source code. Anyone have any tips on how to do it? Do I just put a LGPL header on top of each file and call it a day?
    http://jack.works
  19. #39
    Jul 2007
    1602
    You might want to set up a Source Forge or GIT project
  20. #40
    Feb 2004
    2337
    Great work Jack, Ive only just noticed this. I truely hope it all goes to plan.
    I am contemplating to start a series of videos on youtube titled "CNC on a shoe string budget. I will have a play with PartKam and hopefully include it in the videos.
    Does the top link you posted contain the latest release, and is it always updated, or is that to an earlier release?
    Benny
    Being outside the square !!!
Page 2 of 7 1234
  1. Free 2-D CAD
    By Wolfspaw in forum Uncategorised CAD Discussion
    Last Post: 05-21-2009, 01:12 PM
  2. Free 3d Mechanical Cad Tool, Did anybody try the free 3D CAD too CoCreate is offerin
    By hansge31 in forum Mechanical Calculations/Engineering Design
    Last Post: 06-20-2007, 08:13 PM
  3. Free Doors--Free Cabinet Door Software
    By 1BigPig in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 06-07-2007, 07:36 PM
  4. Free CAM: cam.py
    By FritzX in forum Uncategorised CAM Discussion
    Last Post: 02-24-2006, 06:25 PM
