603,370 active members*
3,591 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > How to attach carbide ?
Results 1 to 10 of 10
    Jan 2010
    In the figure attached, you can see Part A & Part B.
    I want to attach Part B (which is a carbide) to Part A (Steel).
    I know that normally "BRAZING" is done to attach carbide, but it is not a failure proof.
    I have many of pieces (attached by brazing process) do seprate after a period of time.
    I was looking so any other attaching method (other than brazing) to attach carbide to steel which do not seprate for a very long period of time.
    Can anyone suggest me a alternative & failure method of attaching carbide?:
    Ramu
    Jul 2007
    1602
    Are you subjecting them to a lot of heat? What are the working conditions for this item?
    bob
    Aug 2007
    339
    Machine a pocket for the carbide to go into then braze them. You will have more contact area and the pocket will keep it from being jared loose over time.
    Lots of luck to you !
    We all live in Tents! Some live in content others live in discontent.
    Sep 2008
    117
    Carbide should be brazed to steel using trimet.
    http://www.lucasmilhaupt.com/en-US/p...azingalloys/2/
    Gene
    Mar 2009
    13
    Cool Trolling
    Originally Posted by diylife.com.tw
    If you have any assistance which we could serve to you, please do not contact us
    Jan 2010
    Ok,
    It will try to braze through some another material.
    But, it is any other method to fix carbide with Steel.
    Jan 2010
    Hey,
    Machining a pocket in carbide...Seems like a impossible thing....
    Ya, you EDM it but it will take more time.
    Oct 2005
    1237
    Why would you machine a pocket in carbide? You make a pocket in the main part and braze the carbide into it
    Jan 2010
    You Got...Me
    Sometimes my stupid concepts do come out from my brain(chair)(chair) Hitting by Brain...SORRY
    Jan 2010
    Hi
    Also I think i should semi pierce a hole (as shown in figure) so that i can braze on the top as well as along the length of carbide & will ensure more rigid clamping.
  1. Attach Laptop to CNC
    By nk27 in forum DIY CNC Router Table Machines
    Last Post: 10-20-2009, 11:45 AM
  2. How do I attach anything to an X3 head?
    By slashmaster in forum Benchtop Machines
    Last Post: 05-09-2009, 06:09 PM
  3. How to attach flat to box?
    By Apples in forum Mechanical Calculations/Engineering Design
    Last Post: 12-22-2006, 07:44 AM
  4. How to attach lead screw
    By Hack in forum DIY CNC Router Table Machines
    Last Post: 10-06-2004, 07:38 AM
