586,110 active members*
3,419 visitors online*
    Jun 2010
    Servo Drive Issues
    I'm dealing with an old Motch Single Spindle and its been down for two weeks. When the machine is readied up, both X and Y drives (A06B-6058-H005) fault out with HC alarm LED. I think the drives are Alpha series but the facing is gone from both. The operator manual says to look at GFZ-65005E manual from GE Fanuc, does anyone have this electronically or a link?
    So far I've checked incoming voltage. Since its two separate systems faulting at the same time, I'm thinking the Fanuc Controller (A16B-2200-0080) is crapping out or a parameter got changed for the motor setup which I don't know how to access on the 15T controller.
    Can anyone help me out?
    Jun 2010
    Replaced the Servo Controller and the problems seem to be resolved.
    Have you found GFZ-65005E?
    I need to know some servo parameters description.
    I have Fanuc-15M and some problems with Y axis (SV003 - abnormal servo current) in sleeping mode (not moving at all)
  1. Replies: 10
    Last Post: 03-17-2015, 03:52 PM
  2. Z Axis drive issues on Boss 5 machine
    By Gsparkey in forum Bridgeport / Hardinge Mills
    Last Post: 02-04-2010, 04:47 PM
  3. CNC Lathe - Servo direct drive or pulley drive?
    By s76tools in forum Uncategorised MetalWorking Machines
    Last Post: 09-06-2009, 05:17 PM
  4. ims drive issues
    By austin.mn in forum Stepper Motors / Drives
    Last Post: 09-08-2007, 07:36 AM
  5. Drive issues already!!!
    By ty1295 in forum Servo Drives
    Last Post: 09-03-2004, 01:49 AM
