603,348 active members*
2,907 visitors online*
    Aug 2005
    4
    Emco PC turn 120
    I come to buy a pc turn 120
    but there is a probleme when i start for make reference with touch " AUX"
    he display 'l'entreineur principal pas pret" " chuck not ready"
    i think the probleme is in frequency variator, have you some idéa where the probleme come ? in variator only 2 LED is on
    Jan 2006
    121
    try to start Emco pc turn 120
    First of all, set the Rotary Switch in to the left and press buttom AUX in 3-4 sek and deep thump can be heard, it is the oil pumping system. When completed. Press X one time then press Z one time. This will make zeropoint.
    Turn your Rotary Switch to Aut or MIDI or JOG and so on.
    Test in MIDI
    G04 F0.15 S1500 M04 push Enter
    G01 x40 push Enter
    this don´t start any thing but press the green button one´s
    The maschinery process the line one after the other.
  1. EMCO PC Turn 50 Lathe
    By heli_madken in forum EMCO CNC Machines
    Last Post: 03-23-2020, 08:06 PM
  2. Outside jaws for EMCO PC Turn 50
    By thirty78 in forum Benchtop Machines
    Last Post: 09-10-2013, 09:34 AM
  3. Emco Turn 320
    By J_Copeland in forum Want To Buy...Need help!
    Last Post: 10-21-2008, 05:26 PM
  4. EMCO PC Turn 55
    By CatBurke in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-09-2008, 08:21 PM
  5. Emco Concept turn 55?
    By praetor in forum Vertical Mill, Lathe Project Log
    Last Post: 06-08-2008, 06:18 AM
