603,932 active members*
3,382 visitors online*
Hybrid View
gpraceman Milling Slot in 1010 06-17-2010, 06:13 PM
keebler303 Just mill it all and use some... 06-24-2010, 01:41 PM
    I'm looking to mill a 1" x 1/4" slot through the middle of some 80/20 1010 extrusion. I'm a noob with CNC. Would it be best to drill 1/4" holes on the ends of the slot and then mill out the middle or just mill it all out? I was thinking that drilling first would help with chip evacuation. I don't mind the ends having the 1/4" diameter. I just need a way to run some wires from the front channel to the back channel.
    I've got 1/8" and 1/4" Onsrud single flute "O" style upcut bits at my disposal.
    Jan 2006
    2985
    Just mill it all and use some WD-40 or similar for lube.
    Matt
  1. T SLOT MILLING CUTTER PACKAGE 5 (ON WALTER CNC CUTTER GRINDER)
    By dharschman in forum Toolgrinding / Toolgrinding Machines
    Last Post: 09-13-2010, 06:25 PM
  2. Slot milling w/ .0312 endmill
    By extanker59 in forum MetalWork Discussion
    Last Post: 01-12-2010, 03:43 PM
  3. milling deep thin slot
    By dlenardu in forum MetalWork Discussion
    Last Post: 01-26-2009, 03:23 AM
  4. Helical milling a slot
    By kevinheez in forum Surfcam
    Last Post: 05-02-2008, 01:14 PM
  5. Simple slot milling problem
    By jwknow in forum Mastercam
    Last Post: 01-23-2008, 12:03 AM
