586,734 active members*
2,474 visitors online*
Page 58 of 76 848565758596068
Results 1,141 to 1,160 of 1506
  1. #1141
    Jan 2008
    241
    Re: Mach3 2010 Screen set
    After a new computer and monitor, I am setting Mach3 up again, and am having an issue with the diagnostic screen not showing correctly:
    I have no idea how to correct this, help? 1680 x 1050 I'm LOVEN the extra screen real-estate! (from 1024x768)
    EDIT: Never mind, feel like a dumbass now... found the screen divider...
    My Build: http://www.cnczone.com/forums/diy-cnc_router_table_machines/113711-my_build_-_many_thanks.html
  2. #1142
    Oct 2007
    23
    Hi Mogal
    Just out of interest where is the screen divider. ( I'm new to this stuff)
    Cheers
    Andrew
  3. #1143
    Jan 2013
    Hello my name is albert some time buy the mach3 2010 screen set, everything works fine, now I have a new cnc machine, the controller is usb wix hc, everything works right minus buttons homing and probe z, if I run the editor vb script editor select the macro for example m884 works perfectly, but from the button does not work any ideas?
    my windows 7 64bit operating system
    thanks
  4. #1144
    You have to copy the macros from Mach3\macros\2010 into Mach3\macros\yourprofilename\
  5. #1145
    Jan 2008
    241
    If you hover your mouse over the red line area, it will change the cursor and allow you to slide the diagnostic screen.
    Attachment 315124
  6. #1146
    Mar 2010
    813
    Hello Gerry,
    I have to start by saying great screen set and features, could never go back to the default Mach interface. I been using your sceenset with the autochange tool macro flawlessly for some time now. I followed your video tutorial on how to use, and even though it worked a little differently I never thought to address it until now.
    In the tutorial video it shows to do the "initial" auto zero... zeros to material plate, than goes to and zeros fixed plate, than starts cutting.
    With my set up, after the fixed plate zero it goes back to its original X,Y position, I than hit "Cycle Start" it than goes back to tool change position and repeats fixed plate zero before cutting starts.
    I realize the Macro is doing what its suppose to do because my PP is putting a M6 before spindle start. So Instead of trying to modify my PP that I have absolutely no experience with, I'm trying to find a simpler work around. I experimented and seems to work by starting with a "Simple" auto zero than cycle start. This way its only doing a fixed plate auto zero once in the beginning.
    Do you think starting with a Simple zero could cause any problems? Hoping to avoid wasted material or broken bits.
    Thanks in advance,
    Dan
  7. #1147
    Yes, it will. You need to do the initial auto zero to set the location of the fixed plate relative to Z zero. If you do the simple Auto zero, the Z zero will be incorrect after the tool change.
    What CAM software are you using?
  8. #1148
    Mar 2010
    813
    Alphacam
  9. #1149
    The easiest thing to do is probably load the g-code, then click the Edit g-code button and remove the first M6.
  10. #1150
    Mar 2010
    813
  11. #1151
    Jan 2008
    241
    Hi Gerry,
    I do 99% of my work off the table surface. Therefore, I would like to edit the auto
    z code to just touch down once and have that reference both the work, and table.
    I would think this could be easily done, and safe to do so?
    I'm using VCarve Pro with Mach3 and your screenset.
    I'm not sure where to start, if you could point me in the right direction please.
    Chris.
  12. #1152
    Can you clarify what you mean by this?
    I don't understand what you want to do.
  13. #1153
    Jan 2008
    241
    Sorry, sometimes my terminology is lacking
    I don't have a movable reference plate.
    I'm using a permanent fixed plate for both referencing the table, and the work.
    So the auto zero macro touches down on the fixed plate twice.
    (Once to ref the work, then the second time to ref the table)
    Being as my movable plate and fixed plate are the same,
    I'd like it to touch down only once.
    better?
  14. #1154
    Yes. So you really don't use the fixed plate as a reference plate. I'll see if I can do something later today or tomorrow.
  15. #1155
    Mar 2010
    813
    Quote Originally Posted by Mogal View Post
    better?
    So your putting your zero at the bottom of your material and its thickness in your cam software??? Fixed plate is all you would need!!! Great idea..Thanks Mogal!
  16. #1156
    I meant to do this today, but fell asleep.
    I'll try to get to it tomorrow.
  17. #1157
    Jan 2008
    241
    Quote Originally Posted by Dan911 View Post
    I've always found this the easiest way to do things...
    I always know the thickness of the material I'm working with, and when I don't or its not flat, I will measure the thickest area,
    and then mill it flat. Yes, adjusting the thickness in the cam software (VCarve Pro)
    So the touch plate should only have to touch once, as the reference for the table and the material are the same. "ZERO"
    No worries Gerry... Been loving the screenset this many years... I can wait a couple more... days
  18. #1158
    OK, try this.
    Don't use the Initial Auto Zero anymore, as you no longer need to save the location of the fixed plate.
    Just use the Simple Auto Zero to start, and during tool changes, this should basically just do another auto zero to the fixed plate.
    This hasn't been tested, so be careful with it.
    Attached Files Attached Files
  19. #1159
    Sep 2011
    1183
    Gerry quick question will the 2010 screen set work with a touch screen?
    http://www.cnczone.com/forums/diy-cnc-router-table-machines/140832-cnc-software.html
  20. #1160
    Depends on how big your fingers are.
    Any screenset will work with a touchscreen. The buttons may be on the small side in the 2010 screenset, though. I've never tried it.
  1. Mach3 screen set
    By PEU in forum Screen Layouts, Post Processors & Misc
    Last Post: 11-28-2014, 11:00 AM
  2. Econo-Probe Setup with Mach3 + Ger's 2010 Screenset
    By jmc2010 in forum CNC Machine Related Electronics
    Last Post: 06-24-2014, 04:21 AM
  3. G100 + Mach3 2010 screen auto tool zero
    By Menatep in forum G-REX
    Last Post: 05-02-2014, 10:13 PM
  4. Strange Issue with 2010-4 Screen Set in second machine profile
    By JoeKumanchik in forum Mach Software (ArtSoft software)
    Last Post: 03-30-2014, 11:27 PM
  5. New Mach3 Router Screen
    By ger21 in forum DIY CNC Router Table Machines
    Last Post: 07-08-2008, 03:06 PM
