586,999 active members*
3,059 visitors online*
Page 62 of 76 1252606162636472
Results 1,221 to 1,240 of 1506
  1. #1221
    Oct 2016
    9
    Re: Mach3 2010 Screen set
    Thanks Roger,
    I understand the problems of noise. But before I installed this screenset 2010 I had never problems with noise. I used the standard Mach3 profile with a standard probe script for over one year without any problems.
    How is it possible that I have installed this screenset and then I get some noise problems? I don’t get it why. Maybe you can explain it to me.
    Other question is off course how can I get rid of this noise problems if they are there.
    Ritmeester
  2. #1222
    Jun 2010
    4256
    Hi Rit
    In that case I will have to pass you over to Gerry. I have not used his screen set myself for probing.
    Noise - I don't know what your interface looks like, but maybe Gerry does. Sorry.
    That said, small filter caps are often involved, plus some SW filtering in Mach.
    Cheers
    Roger
  3. #1223
    Oct 2016
    9
    Thanks Roger,
    I hope that Gerry will join in.
    Ritmeester
  4. #1224
    Mar 2010
    621
    Jerry,
    How do I adjust the length of the Second Edge probe? I need to go further into the Y+ Axis...
    Gecko G540, Rack and Pinion Drives-X and A axis, 1/2-10 5 Start Acme-Z Axis
    4-THK HSR 25 Linear Slides, KL23H2100-35-4B, Power Supply-KL-600-48 48V
  5. #1225
    Aug 2009
    52
    Ritmeester, Did you ever get your auto zero probing to work properly? I am having the exact same issue. I downloaded and installed the new M909.m1s file into my profile macro folder and restarted Mach3 with 2010 Screenset as I think you were advised to do, but the probe still goes down after initial zero probe. I looked at the probe line with a 200Mhz scope and found less than 20mV noise and no spikes at all. my Mach 3 profile is set up for 6ms (150 units) debounce time. Any help or advice is appreciated!
  6. #1226
    Jun 2010
    4256
    6 mS is rather long. I think I run 1 mS SW debounce, and that works fine with g31/ESS/Mach3.062/XP
    Cheers
    Roger
  7. #1227
    Aug 2009
    52
    Thanks Roger, Absolutely right. I ran it up to 6ms to get a troubleshooting data point. I normally run it at 1ms with no issues, although 6 ms translates to just .001" at 10 ipm.
    Noting the general consensus that noise is the usual culprit (although I see none with the scope), I just tried adding an RC network to the probe input on my C10 breakout board (which has a 4.7k pull up to 5V) with 470 Ohms in series with the probe and 1uF from the input to ground. This gives a TC of 0.5 mS. The resulting voltage divider still provides a low of 0.45V which satisfied the 74ACT245's max low input of 0.88V.
    After this mod, I still get the erroneous zero probe behavior where after first touch, the probe continues to go down after short delay, so I remain befuddled. Again, any suggestions are most welcome.
  8. #1228
    Oct 2016
    9
    paulcc,
    In a total 30 to 40 times trying I get some 4 or 5 times a good working probe. The rest is wrong. I did not download the new M909.m1s macro. I didn’t know of this new macro.
    Do I need this macro? I have a X6-1500C USB from Omiocnc
    Regards,
    Ritmeester
  9. #1229
    Jun 2010
    4256
    Hi Rit
    Hum. Not good. I wonder about the probe itself? or the cable?
    Cheers
    Roger
  10. #1230
    Aug 2009
    52
    Quote Originally Posted by Ritmeester View Post
    paulcc,
    Regards,
    Ritmeester
    I was reading the thread in the wrong order when I assumed the macro was suggested as a fix to our issue. It is not necessary. I am still working on the assumption that the issue is noise, but I don't see any with a 200 mHz scope. Maybe it is high speed transients that my Chinese scope isn't triggering on?
  11. #1231
    Oct 2016
    9
    I can’t go further with this. I have restored a image back on my computer with the original Mach3. (I always make a Ghost image from my PC when I install something like this) And all works perfect again
    I must make production. For this time I must give it up and throw away $27.- . and € 95.- for a 1980x1080 monitor.
    It is as it is.
  12. #1232
    Aug 2009
    52
    If I ever get it solved, I will surely post the fix for you.
  13. #1233
    Jun 2010
    4256
    If the transients are THAT fast, then I doubt Mach or the PC will see them either.
    Cheers
    Roger
  14. #1234
    Aug 2009
    52
    I guess I'm thinking it could be a triggering issue, not necessarily a bandwidth limitation. For now I am stumped.
  15. #1235
    sorry I've been out of the country for the last 10 days.
    I'm at the airport now I'll look into this when I get home tonight
  16. #1236
    Aug 2009
    52
    Gerry, No worries, all things in their good time:-)
  17. #1237
    Do you know what motion controller the machine is using? Most chinese Mach3 motion controllers do not handle probing properly.
    Also, what version of Mach3 are you using? Do NOT use the current version, 3.043.066. Use 3.043.062 instead.
    If it's a chinese motion controller, send me an email, and I'll send you some different macros to try.
    - - - Updated - - -
    Quote Originally Posted by paulcc View Post
    Paul, what motion controller are you using?
  18. #1238
    Mar 2010
    621
    Quote Originally Posted by adam_m View Post
    Jerry,
    Gerry, if you get an opportunity now that 're back could you take a peek at my question when you get some time?
  19. #1239
    Jerry,
    Find this block of code, and change this line.
    'Move around corner for X Probing
    Code "G91"
    Code "G0 X-" & CornerClear + 2*ProbeD
    While IsMoving
    Wend
    Code "G0 Y" & 2*ProbeD + Clearance
    While IsMoving
    Wend
    Code "G90"
    Right now it moves 2x the probe diameter.
    You can replace "2*ProbeD" with a value, like 1.5.
    Code "G0 Y" & 1.5 + Clearance
    There are 4 corner macros, M905-M908.
  20. #1240
    Aug 2009
    52
    Also, what version of Mach3 are you using? Do NOT use the current version, 3.043.066. Use 3.043.066 instead.
    - - - Updated - - -
    I am using old school Windows XP with parallel port run by Mach 3 V 3.043.066 - no motion controller at all. I cannot yet find a link to V 3.043.062 at the NewMangled solutions website.
    UPDATE - Just found link to 3.043.062 at Warp9 site. I'll install and report results ASAP
  1. Mach3 screen set
    By PEU in forum Screen Layouts, Post Processors & Misc
    Last Post: 11-28-2014, 11:00 AM
  2. Econo-Probe Setup with Mach3 + Ger's 2010 Screenset
    By jmc2010 in forum CNC Machine Related Electronics
    Last Post: 06-24-2014, 04:21 AM
  3. G100 + Mach3 2010 screen auto tool zero
    By Menatep in forum G-REX
    Last Post: 05-02-2014, 10:13 PM
  4. Strange Issue with 2010-4 Screen Set in second machine profile
    By JoeKumanchik in forum Mach Software (ArtSoft software)
    Last Post: 03-30-2014, 11:27 PM
  5. New Mach3 Router Screen
    By ger21 in forum DIY CNC Router Table Machines
    Last Post: 07-08-2008, 03:06 PM
