We have a vmc 15 that is making significant errors at feed rates of 150 ipm. What we are doing is making a vacuum chuck out of a plastic material with .100 grooves. Because of the soft material we cranked the feed rate up to 150 but noticed that at the junction of the grooves the dimensions (width) of the grooves go to crap. I redid the piece with a feed rate of 30 ipm and the piece was fine. I am new to cnc machines, are high feed rates while making turns like I am doing usually a problem? We did recently have the keyboard board go bad and upon replacing that and getting the machine back up and running noticed that the rapid traverse rates did seem a bit faster than I remember, but I cant imagine the keyboard board would effect that. Looking for input as to whether I am am just exceeding the limits of the machine or there is a bad setting or parameter? I adjusted the backlash parameters several weeks ago and ended up raising most of them by 3 tenths.
Thanks for any input
