603,898 active members*
2,714 visitors online*
    Aug 2004
    421
    anyone know what size spanner wrench?
    I need spanner wrenches for the boss quick change collet system. I need both the one for the big locking nut (forgive me, I dont know the proper terms) and one for the nut on the actual chuck. Does anyone know what size they are? I'm going to try and order them from mcmaster. Does the sizing just go by the OD of the nut?
    thanks
    24260
    Would that be Universal Kwik-switch 300?
    Al
    Albert E.
    Aug 2004
    421
    I think so? I cant find anything that says what type it is.
    24260
    If it is Kwik switch, I got the fixed pin C-Spanners from Reid Supply
    https://reidecom.reidtool.com/xephr/edit/ITEM_GROUP, look for the closest to the your dia, for Kwik there is two sizes.
    The wrench on mine is a standard 1 1/4" open-end.
    Al.
    Albert E.
  1. Does size really matter?
    By DAB_Design in forum CNC Machine Related Electronics
    Last Post: 03-20-2005, 11:27 PM
  2. Ball Screws and machine size?
    By swiftden in forum DIY CNC Router Table Machines
    Last Post: 02-03-2005, 11:02 PM
  3. Ballscrew size -vs- project size
    By Alan T. in forum CNC Machining Centers
    Last Post: 10-19-2004, 02:53 AM
  4. size of 4th axis drive
    By converterk in forum Centroid CNC Control Products
    Last Post: 06-07-2004, 04:01 PM
  5. What size steppers?
    By cnczoner in forum Uncategorised MetalWorking Machines
    Last Post: 05-19-2004, 05:32 AM
