586,655 active members*
4,687 visitors online*
IndustryArena Forum > MetalWorking Machines > HURCO > "Security Device Invalid or Has Failed"
    Apr 2008
    123
    Hi all,
    Today in mid tool change my VSX24 Bedmill shut down and I was left with this message on the console screen.
    I could do nothing atall and even after 2 consecutive reboots I was unable to clear it.
    Anyway after a quick search here I found that it was a 'Dongle' atop the cpu control next to a ribbon cable that was to blame.
    I removed it, re seated it and tried agan..No Luck!!!
    So afyter a short call to Hurco support UK I was told I needed to send them the dongle for them to reprogram and return to me.
    So I asked if there is anything else that could be done and they said Yes they could make my machine 'Dongle Free' but thier technician could still have to call to do it.
    So with the boss's permission I took that course of action.
    The tech is coming tomorow...
    Anyway my question is could another fault be to blame for causing my problem?
    Sorry its long winded guys.
    Apr 2008
    123
    UPDATE...
    The Hurco tech came this morning and found that the CPU mainborad was goosed and replaced it with a modern version.
    We are now Dongle free (as they are obsolete Im told)
    Everything works fine and just as before.
    He did mention that the Z axis bearings where a little noisy..
    Looks like they are the bext fix..
    Thanks for listening guys.
    Back to making chips for me !!! :-)
  1. Hawk150-Acramatic2100 "NC Engine Failed"
    By espinja in forum Cincinnati CNC
    Last Post: 12-16-2022, 10:05 PM
  2. Error: Security Device is Invalid or has Failed
    By mohammadali in forum HURCO
    Last Post: 10-20-2020, 03:32 PM
  3. "motor steps per resolution" and "driver microstepping" settings
    By margni74 in forum LinuxCNC (formerly EMC2)
    Last Post: 10-24-2009, 08:33 AM
  4. "J" head type "millport"(tiwan,1980) clutch
    By marksbug in forum Bridgeport / Hardinge Mills
    Last Post: 08-17-2009, 04:48 PM
  5. Optical mouse as a 2D-feedback device for "servos" (or steppers)
    By sandos in forum DIY CNC Router Table Machines
    Last Post: 01-23-2009, 03:02 PM
