586,069 active members*
3,714 visitors online*
    Jun 2009
    16
    Question Plate Marking and Center Punch options for CNC Plasma
    Looking for opinions on plate marking and engraving tools to attach to the gantry. Want to mark center holes and also be able to make lines and small text.
    Is there anything suitable that is less $ than the CP 9361? CP makes a smaller 1cfm unit for a lot less $ but I wonder if it has enough power to mark steel.
    Is there an electric engraver that would work?
    Chester.
    Sep 2008
    18
    how much more powerful is the pneumatic engraver compared to a plain ol' electric engraver?
    maybe a dremel with a small carbide burr, you will have a go pretty slow but it would work.
    Jun 2009
    16
    Hey 4130,
    I think an electric engraver would work fine but my concern is that it would need a good z reference so the cutter wouldn't get jammed into the work.
    I wonder if anybody has experience with an electric engraver.
    Plain ol Bill is building one using the CP air scribe so I'm hoping he will post some of his results once it's up and running.
    Chester.
    Nov 2007
    343
    Worked on mine a little today but ran out of time. I was plumbing air and running 120V to the solenoids. Getting close but not quite done.
    Dec 2007
    93
    Pneumatic air scribe link
    Guys,
    Unixadm built an air scribe and has everything documented in his table build. Here is the link to his posts:
    http://www.cnczone.com/forums/showth...=104978&page=2
    He used the pneumatic version and has everything well documented along with videos. He also worked with Less from Sheetcam to have a custom post written.
  1. How to build own CNC Plasma Cutting, Router, Marking
    By kuhesa in forum Uncategorised MetalWorking Machines
    Last Post: 05-31-2010, 12:18 AM
  2. need help marking plate
    By plasma guy in forum Waterjet General Topics
    Last Post: 03-24-2010, 01:48 PM
  3. touch plate with center finder port n pin
    By DanOSB in forum Mach Software (ArtSoft software)
    Last Post: 12-21-2009, 07:56 PM
  4. Pneumatic punch marking tool
    By Fiero Addiction in forum Uncategorised MetalWorking Machines
    Last Post: 05-10-2008, 07:35 PM
  5. CREATE FONTS FOR MARKING??? (PLASMA)
    By tibet in forum NCPlot G-Code editor / backplotter
    Last Post: 04-20-2008, 08:34 AM
