603,936 active members*
3,667 visitors online*
Results 1 to 9 of 9
    Oct 2009
    32
    how to switch off only A axis?
    hello,i have A axis , and when i turn my machine in Mach ,all 4 engines of machine get current ,sometimes ,i want to be able to turn A axis manualy without turning off machine,so i want to turn off only A axis...can i do that in Mach or i should put a swich in A axis wire? Thanks
    Feb 2007
    4550
    Post
    Just disable the A axis in the Ports & Pins "Motor Outputs" Config Menu.
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
    Oct 2009
    32
    Quote Originally Posted by jalessi View Post
    thx jalessi,but as i remember i did that,but problem was that current still coming in my A axis making it not possible to rotate it by hand while the machine is on. i will try it again...
    Feb 2007
    4550
    Post
    Xaco,
    Sorry for the confusion.
    Most stepper drivers have a enable-disable terminal, see attached image for an example.
    This will allow the motor to free wheel.
    Jeff...
    Oct 2009
    32
    Xaco,
    Jeff...
    yes,that would be it ,i was hoping i can do it in mach3 in a way.....anyway..thank you
    Feb 2007
    4550
    Post
    Xaco,
    You could assign an available output pin to control the enable-disable function of the stepper drive.
    Jeff...
    Oct 2009
    32
    Xaco,
    Jeff...
    what if i just cut the wire from box to motor and put a switch,how many wires can i expect? and would it hurt my machine if i swich off and on with swich during mach3 is working?
    Jun 2005
    138
    Quote Originally Posted by xaco View Post
    YES, it will probably damage your controller card, as every controller I have ever seen warns specifically NOT TO connect or disconnect a motor while the controller card is powered.
    Oct 2009
    32
    Quote Originally Posted by Dorsal View Post
    is it ok to swich it of and on while mach3 is off? or if its not working gcode at a moment? or it would hurt if i swich of and on even if only mach3 is on...when exactly it wouldnt hurt to swich on and of?
  1. TM-1 Y axis limit switch alarm
    By jwknow in forum Haas Mills
    Last Post: 10-26-2007, 09:53 PM
  2. How to switch axis directions?
    By juzwuz in forum LinuxCNC (formerly EMC2)
    Last Post: 01-01-2007, 03:05 AM
  3. Y axis limit switch
    By raytor in forum Benchtop Machines
    Last Post: 10-10-2006, 02:48 PM
  4. Z axis zero indicator switch
    By cnc rider in forum Mach Mill
    Last Post: 09-29-2006, 05:00 AM
  5. home switch for rotational axis
    By xyz100 in forum DIY CNC Router Table Machines
    Last Post: 07-31-2006, 07:14 PM
