588,616 active members*
4,140 visitors online*
    Aug 2010
    Unhappy NT4250 Tool Pre-Setter alarm
    After adjusting x and z value for turret#2, I have EX1992 alarm every time I install tool presetter and also the PST button doesn't work too. When I remove the arm alarm goes off.
    Any help? Thnx
    Apr 2006
    7
    Hi
    How much did you adjust it by and have you tried putting the old values back in?
    Matty
    Feb 2009
    6028
    So I would assume this is a removable presetter. If there is no alarm with the cap on, but it alarms with the arm in, I would assume either the contacts are not mating up with the mount correctly, or the head went bad in the arm. If the machine does not see the correct signal from the arm, it will not go to PSM mode.
    PS, I have seen the contact pins on the arm/mount actually broken off, check there first.
  1. Tool Setter Macro for M-V60C and Metrol Setter
    By mitshack in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 02-02-2013, 12:08 PM
  2. Tool Pre Setter
    By Allen123 in forum Mach Software (ArtSoft software)
    Last Post: 03-16-2009, 05:29 AM
  3. Tool setter macro for M-V60C and Metrol setter
    By mitshack in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-06-2008, 02:38 PM
  4. Tool setter alarm
    By Nine Blue in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 02-18-2007, 01:00 AM
  5. tool setter
    By ACME in forum MetalWork Discussion
    Last Post: 07-30-2005, 05:15 PM
