587,362 active members*
3,605 visitors online*
Results 1 to 8 of 8
    Jan 2008
    1538
    Newcastle: Beginning of build plan
    Hi guys,
    I live in Newcastle. I've toyed with the idea of a CNC mill for years, but never done anything about it. I was impressed with what a friend of a friend's a cheap little kit was able to do and have decided to build something myself.
    My thoughts are very preliminary so far. I don't actually have a specific product that I want to produce with this machine, it's more about making it.
    Choice of linear motion:
    I popped into a couple of the bearing suppliers in town, and it seems like I'm looking at ~4.50 per standard skate bearing. At that price I'd think it would be better to do this sort of bearings.
    Is there a list of good suppliers? The list here is from 2004 and fairly useless.
    Also popped in to Alspec aluminium, they only had quite simple extrusions, nothing to come close to 8020 sort of stuff. Is that available locally?
    Ideally I'd like to end up with a machine that can handle plastics, aluminium and copper. Probably only need a work area of 300mm x 300mm x 50mm for that stuff, though if I'm building one that will only really handle wood and plastics I'd probably aim a fair bit bigger.
    Tools on hand are drive, circular saw, small cheap drill press, cheap GMC router.
    At my dads place in Blue Mountains I've got a metal lathe and mill, but I'm only down there for a day or two every few months.
    Jul 2009
    99
    G'day Pippin88,
    I too am in Newy. Currently building an MDF CNC (see build thread link below). Using skate bearings for X & Y axis and linear bearings for the Z axis. Got my skate bearings from VXB.com (US), 50 bearings in total for $58 US including shipping. The linear bearings and shafts I got from the same ebay mob you've looked at. Product seems good (for price....) and prompt service, although they haven't been given a work-out yet!
    I priced some 8020 al (25-5010, 50mm x 100mm T-slot) from http://www.8020.com.au/ (Seven Hills, Sydney) and the quote came back at $320 for a 4metre length! Unfortunately not in my budget! Haven't investigated if it's available anywhere else in Aus.
    This forum has a wealth of information, it just takes time to find it......! Try also http://www.woodworkforums.com for Aussie built metal and timber DIY CNC.
    Good luck mate. Keep an eye on this forum, there is possibly going to be a get togethor bbq for interested Newcastle people soon.
    - Craig.
    my JOES2006 build thread - http://www.cnczone.com/forums/showthread.php?t=106995
    Jun 2010
    4259
    Economics???
    Quote Originally Posted by craigjh View Post
    Forgive me, but ...
    Given how much anyone will have to spend on the software (Mach3?), the servo amplifiers, the motors, the encoders (if not steppers), the drive screws, the bearings, etc, I don't understand the use of MDF instead of something more substantial for the frame. Nor do I understand the use of soft aluminium angle for the ways instead of a few lengths of ground steel rod.
    Just how much can you save by going the MDF route (out of what total)? Seriously?
    Cheers
    Dec 2007
    362
    For an alternative to the 80/20 extrusion, you could try AME.
    Their extrusion range is not as large as 80/20, the biggest they carry is 80x80, but is considerably cheaper.
    Regards
    Geoff
    Jul 2009
    99
    Question
    Quote Originally Posted by RCaffin View Post
    Forgive me, but ...
    Cheers
    I see a DIY build more as a learning process (especially the first build.....) and I guess you're limited to using the tools and materials that you have and are comftable with. This translates into a timber build for some, an aluminium build for others, and a steel build for the rest.
    Not sure what you mean by the "soft aluminium angle for the ways" comment.
    Some of the variety of the MDF DIY builds are producing fantastic results and, more importantly, giving a few of us an introduction to CNC. Including materials, software, motors, electronics, hardware, etc, my machine will come in around $1500. I don't include my labour cost in that due to it currently being a "hobby".
    - Craig.
    Jan 2008
    1538
    Thanks for the input guys.
    I'm more seriously looking into purchasing a mini mill and converting it at the moment.
    Metal, and to a lesser extent plastic, have always been my materials of choice.
    Hopefully I can end up with both.
    I'm looking at the X2 from Hare&Forbes. $869.00.
    Are BF20 clones available in Aus?
    Oct 2006
    6
    Quote Originally Posted by pippin88
    Sounds like somebody has been following the mighty Hoss like I have.
    The only supplier I have found so far has been Titan machinery
    Todd
    Oct 2006
    6
    Red face
    Quote Originally Posted by pippin88 View Post
    Sorry I forgot about another ...
    McJing
  1. Beginning to build my Z-axis.
    By zonk2 in forum DIY CNC Router Table Machines
    Last Post: 12-23-2008, 06:17 AM
  2. Questions for a 5x10 build plan
    By rpgdeity in forum Waterjet General Topics
    Last Post: 10-28-2008, 01:05 PM
  3. on the hunt for a small 3 axis home build plan
    By RichB77 in forum Vertical Mill, Lathe Project Log
    Last Post: 10-17-2008, 10:05 PM
  4. Build Log - hack's plan
    By bryanrabb in forum DIY CNC Router Table Machines
    Last Post: 03-23-2006, 04:57 PM
