586,616 active members*
2,410 visitors online*
    Oct 2009
    32
    how to make 4th axis move continuosly?
    hello,my 4th axis is moving in steps of 1/4 of a degree,what can i make to make it move continuously? i have some motor on 4th axis thats written on it 2 steps/degree.its not microsteper motor and its dirctly conected to my 4 jaw chuck ,it dosnt have transmission. in mach3 i put in motor tuning in "steps per" box-4...so i have 4 steps per degree but always in steps...is there any way i can make it move continously?
    Jan 2006
    357
    This is from the mach3 yahoo group,
    Config> ports and Pins> motor output> enable the spindle and enter the pin
    numbers for the indexer step and direction pins.
    Don't forget to click on apply.
    Next, click on Config> ports and Pins> Spindle set up> put a check mark in"Use
    Spindle Motor output" and another check mark in step and direction.
    Last go to
    > config> pulley set up
    and provide the necessary info.
    Then in your G code you will need the M3 command and the S value.
    Such as S 200 for 200 RPM
    Oct 2009
    32
    Quote Originally Posted by GaryCorlew View Post
    Last go to
    i was taking about 4th axis,my spindle is separate from any pins and ports..but thnx... by the way ..my motor on 4th axis is 2deegrees per step,not 2 steps per degree as i mentioned..
    Jan 2006
    357
    Quote Originally Posted by xaco View Post
    Yes I know, but that is how it is done
  1. How to you make a stepper motor move?
    By HereinCS in forum DIY CNC Router Table Machines
    Last Post: 08-24-2010, 06:45 AM
  2. Does a DRO make X Y Table Move?
    By theNaTural in forum Charter Oak Automation Support Forum
    Last Post: 06-13-2008, 06:06 AM
  3. Replies: 5
    Last Post: 12-06-2007, 02:50 PM
  4. Cant make it move
    By hugo carradini in forum CNC Machine Related Electronics
    Last Post: 10-12-2007, 11:50 PM
  5. Software to follow a spline continuosly
    By fsalla in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 09-23-2005, 01:01 AM
