I need to make a fairly dense spiral 10 revolutions. with about .25" between walls. can someone suggest a way to do this? thanks.
R.
R.
Sure, make a very expensive mandrel. Which might be a bit price prohibitive depending on the quantity you actually need?
That or source it out: http://www.falconindustries.com/conveyor_screws.htm
Regards
The Manufacturing Reliquary
http://cmailco.wordpress.com/
You don't mention the cross section of the material, but if it is not too stiff, and you have a heavy duty lathe, (with a very slow speed) you could wind it like winding a custom spring. You can wrap it around a threaded mandrel at your desired pitch, or wind it with a "spacer" like this:
http://chestofbooks.com/home-improve...il-Spring.html
Keith
NEATman
Basic research is what I'm doing when I don't know what I'm doing. Wernher von Braun
thanks for advise i think i found a bendable plastic alternative.
