603,893 active members*
3,204 visitors online*
IndustryArena Forum > MetalWorking > Moldmaking > casting bronze nuts
Results 1 to 6 of 6
    Mar 2009
    17
    casting bronze nuts
    I have an acme screw but find the bronze nuts expensive at 25$ each.
    can anyone give some tips on bronze casting?
    can i use the acme screw as the mold and pour bronze around it ,
    or will the bronze contract and seize on the screw?
    Jan 2007
    355
    That sounds like a lot of work, and you won't be pleased with the results.
    Why not just buy a flanged brass bushing, drill it out to the correct diameter, then tap it with a combination roughing / finishing acme tap?
    Diplomacy is the art of saying "Nice doggie" until you can find a rock. - Will Rogers
    Mar 2009
    17
    tks
    Thanks that's just what I needed - now I just gotta find an acme tap....maybe its easier than i thought as the acme profile is trapezoidal and not curved, iirc
    Nov 2003
    154
    Spend the $25 on the already tapped nut. It is going to cost you 3-5 times that to buy an acme tap.
    Mar 2009
    17
    I'll need 12 or so of the nuts so maybe buying a tap and diy is what I'll need to do.
    May 2004
    162
    Bronze
    Quote Originally Posted by rutman View Post
    Did you get you're nuts done?
  1. Two bronze nuts better and cheaper then one bronze nut ?
    By vroemm in forum Mechanical Calculations/Engineering Design
    Last Post: 09-27-2008, 04:18 PM
  2. TIG Welding Bronze Casting?
    By Geof in forum Welding Brazing Soldering Sealing
    Last Post: 07-06-2008, 10:41 PM
  3. Urethane Resin Casting: Linear Glides & Leadscrew Nuts
    By scratch_6057 in forum DIY CNC Router Table Machines
    Last Post: 03-26-2006, 08:13 PM
  4. Nuts are driving me nuts!
    By Cold Fusion in forum Community Club House
    Last Post: 06-13-2004, 05:40 AM
