587,214 active members*
3,634 visitors online*
IndustryArena Forum > Other Machines > Engraving Machines > Laser cut thin carbon fiber
Results 1 to 6 of 6
    Aug 2007
    422
    Question Laser cut thin carbon fiber
    Hello, I have a 120 watt co2 laser and would like to cut thin C.F. thickness would be 1/16" or thinner.
    1. can it be done?
    2. do I need any additives (pastes)?
    3. what is the finish like?
    4. any other advise?
    I have a router but don't want to use it due to the hazardous dust that is made.
    Necessity is the mother of all invention (unknown)
    My club home page www.lhmac.org
    I think you will need a lot more power than that to get a crisp edge. Too little power just burns the resin.
    The bottom line, of course, is try it and see
    Good luck,
    Tweakie.
    CNC is only limited by our imagination.
    Aug 2007
    422
    Thanks tweakie, I was hoping to find others who have done this before I blow $50 on something I can't cut. I don't have ant c.f. that would work laying around.
    Aug 2007
    422
    Has anyone done this?
    Jun 2005
    138
    Most laser-cutting shops will quickly back away from a job to laser-cut any carbon fiber products, because it is very difficult. After all, the material is ALREADY carbon, so you can't oxidize it any further (which is what a laser does). It takes a high-powered pulsed laser system, and the beam splatters significantly at less than 1/8" of depth.
    btw, the dust from machining cured CF products is not "hazardous" in the sense of poisons or solvents, it is ultra-fine dust which is chemically inert to the human body. The problem is the inertness, because your body won't "reject" it, so breathing it can cause "miner's lung" disease - lungs filled with charcoal (carbon) dust.
    Aug 2007
    422
    Thanks for the info Dorsal. I found some flat c.f. 6mm x 1.0mm and figured I'd see if I could cut it. Sure enough, it cut real nice and left a smooth edge. here is a link to the product.
    http://rcfoam.com/cart.php?target=pr...category_id=96
    I only used 50% power also.
  1. laser cut carbon fiber laminates?
    By dalianharley in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-06-2010, 11:24 PM
  2. Tools for machining solid carbon (not carbon fiber)-more posted
    By camcutter in forum Composites, Exotic Metals etc
    Last Post: 04-28-2007, 12:23 AM
  3. Laser + carbon fiber = ??
    By theclive in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-29-2007, 12:04 AM
  4. Carbon fiber
    By CNC Pro in forum Community Club House
    Last Post: 03-13-2004, 11:32 AM
  5. carbon fiber
    By Hobbiest in forum DIY CNC Router Table Machines
    Last Post: 01-23-2004, 10:40 AM
