588,548 active members*
5,051 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > ES 4020, OSP 700M Vertical Mill, Photocell Switch shorted out
    Jan 2010
    6
    Exclamation ES 4020, OSP 700M Vertical Mill, Photocell Switch shorted out
    The photocell that tells the machine when the tool is in position during the tool change, shorted out and has knocked out the control circuit. Now I don't have any power to any of the swithes. Can anybody tell me where I can reset the control circuit?
    24221
    Most likely a 24vdc supply has been knocked out, if you have the machine schematics it should indicate a fuse or breaker, possibly on either side of the supply, AC in and DC out.
    If the short is still present, it can put a switching supply in shut down until the short is removed.
    Al.
    Albert E.
    Jan 2010
    6
    Smile
    We found the breaker, it is nonresetable. We have 117 volts on the AC side and 0 volts on the DC side. I'm going to try to find one. Thank you for your help. The photocell plug got coolant inside and shorted the connection. I bought a new photocell and new plug & wire.
  1. Daewoo 4020 Mill Spindle Belt Breaking
    By Mark18969 in forum Daewoo/Doosan
    Last Post: 09-16-2009, 05:06 PM
  2. Iduma Vertical Mill
    By industrialmach in forum Want To Buy...Need help!
    Last Post: 05-02-2009, 03:26 AM
  3. Go-Well vertical mill
    By Matt130 in forum Benchtop Machines
    Last Post: 08-14-2008, 08:09 PM
  4. I am purchasing a HF 12 x 36 and HF vertical mill
    By DrDudley in forum Want To Buy...Need help!
    Last Post: 07-02-2008, 10:00 AM
  5. Best Vertical Mill?
    By bvandenb in forum Haas Mills
    Last Post: 04-20-2005, 11:47 AM
