Chris... I just whipped out an exhaust deflector for you. The piece of HDMW I had on hand was just slightly smaller than the diameter of the Hitachi router body but is larger than the diameter of the cast exhaust ports. Being smaller than the router body is important as it shouldn't interfere with a typical dust shoe attachment method.
It took me about 10 minutes to turn and drill the attachment holes. I put it on my router and it fits perfectly and works great! It's sitting here waiting to go into Hitachi service...! OH... I used M4 (I think that's what they are...) flat headed socket cap screws to replace the two screws that attach the bearing dust plate. You remove the dust plate screws and put the deflector over top of the plate... line everything up and install the two slightly longer replacement screws. I took the collet nut off just to make things easier. Simple.
Happy cutting!!!
Steve
aka BOOMER52 >>> http://www.rcgroups.com/forums/member.php?u=159693
