586,036 active members*
3,605 visitors online*
IndustryArena Forum > CAM Software > Uncategorised CAM Discussion > drilling and thread M16 Bobcam and Mazatrol M-2
    Nov 2005
    57
    My milling Machine is a MAZAK VQC 20/40B with Mazatrol cam M-2 controller year 1986.
    My program is Bobcad cam V23 with Predator postprocessor and I am very hapy with the program,it has worked well
    so far.
    However now I have a problem,
    I trayed to thread a hole 14.2 mm with M16 pitch 2.
    The MAZATROL CAM M-2 - METRIC Mill Post processor out puts through Predator Cnc editor the folowing Code.
    Result for the code is bad and sure is it should not have M33 function on line N34.
    O100 (GWINT.NC)
    N1 (TUE. 10/12/2010 06:04PM)
    N2 ( MAZATROL CAM M-2 - METRIC Mill )
    N3 ( T1 CENTER DRILL , DIAMETER = 6.35 , LENGTH = 127.)
    N4 ( T2 DRILL , DIAMETER = 14.2 , LENGTH = 127.)
    N5 ( T3 SPIRAL TAP , DIAMETER = 16. , LENGTH = 127.)
    N6 G90 G80 G17 G00
    N7 G91 G28 Z0.
    N8 G91 G28 X0. Y0.
    N9 M06 T1
    .......................................For shortening the program.
    N29 M06 T3
    N30 M03 S236
    N31 G54 G90 X0. Y0.
    N32 G43 Z3. H3
    N33 M08
    N34 M33 (Wrong G-code becouse its command for tool measure unit out on mazatrol M-2 )
    N35 G84 G98 X0. Y0. Z-36. R3. F2.
    N36 M32 (These I belive cancel M33.)
    N37 G80
    N38 M09
    N39 M05
    N40 G91 G28 Z0.
    N41 G91 G28 X0. Y0.
    N42 M02
    N43 M30
    Can any with knowledge on my type of machine aswell as Bobcad/cam V23 give some knowledge
    or even better tell how to make changes in the postprocessor (MAZATROL CAM M-2 - METRIC.Mill)
    so it will give apropiate cod for the work.
    Thank you in advance
    Sve0019.
    Oct 2006
    173
    Modifying a post.
    Modifying the post is simple watch the video below then print the documentation only if needed.
    Here are instructions on how to modify the post.
    How to modify a Post Processor
    Here is a video on how to modify the post.
    [nomedia="http://www.youtube.com/watch?v=0LZr7I5lTH8"]YouTube - How to make a simple modifacation to a post processor BobCAD V23[/nomedia]
    Nov 2005
    57
    Quote Originally Posted by Sowen View Post
    I did not ask how to edit post processor thats is easy,just to open it
    in notepad.Did you notice its was G codes in the thread,I was send that code
    with the porpouse some maybee you or somebody else know how to
    corigate the Postprocessor the way it will give proper G code for the functions
    I needed.Please notice M33 Tool measure out,I do not know thot the hell
    its doing there.If you know mazatrol M-2 and Predator,write me a working
    postprocessor.
    Sve0019
  1. mazatrol thread milling
    By cr500 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 04-13-2009, 02:48 PM
  2. thread milling in nexus using mazatrol
    By uperez in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 03-31-2009, 09:06 PM
  3. bobcam v12.5.2
    By vividdezigns in forum BobCad-Cam
    Last Post: 08-19-2008, 07:48 PM
  4. Mazatrol variable thread lead?
    By extanker59 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 06-24-2008, 07:24 PM
  5. Mazatrol T Plus thread cycle in synch?
    By Castle1 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 03-26-2007, 04:22 AM
