Originally Posted by
samco
explains how to run a brushless drive with a brushed motor. IIRC you need to switch the phasing swith to off (60deg instead of 120deg)
Correct, if using a BLDC the Hall sequence has to be correct also, set for 60° for brushed servo using U & V outputs.
Also the enable has to be set on, there is an internal jumper that will change the logic for on/off designation (active high,or active low).
Al.
Albert E.
