588,206 active members*
4,315 visitors online*
    Oct 2010
    LPT PIN 1 Voltage Problem - (with TB6560)
    Hello,
    i have problems getting x axis to work on my TB6560 Board.
    The TB6560 Board has the X axis step pin on PIN 1 (LPT). On this pin i measure permanent 0,22V.
    The y and z axis are working fine. On the step pins of them, i measure 0 V when axis is inactive and -0.02V when active.
    So it seems that the not working X axis is caused by a permanent voltage on the step PIN 1. Can somebody give me some advice how to get rid of this voltage - or is there another may to change the step pin to a different PIN ?
    Regards from Germany
    Andy
    Apr 2012
    I know this is an old thread but I have the same exact problem, the x is dead. The led for the x lights up when x is called to work but no current to the motor. any help. I am using Mach3 controller and TB6560 3 axis blue board.
  1. Problem with TB6560 Boards/Computers
    By Scheer in forum CNC Machine Related Electronics
    Last Post: 01-04-2011, 02:54 AM
  2. TB6560 non constant voltage on X axis
    By telah in forum CNC Machine Related Electronics
    Last Post: 10-01-2010, 07:09 PM
  3. Series I Y axis voltage problem
    By batterzazu in forum Bridgeport / Hardinge Mills
    Last Post: 09-30-2008, 02:36 PM
  4. HOT motors. Voltage problem ?
    By DJ Morrow in forum CNC Machine Related Electronics
    Last Post: 11-25-2005, 06:41 AM
  5. PowerSupply Voltage problem
    By grabben67 in forum CNC Machine Related Electronics
    Last Post: 01-26-2005, 01:56 PM
