586,655 active members*
2,950 visitors online*
Results 1 to 6 of 6
    May 2009
    63
    1/2 ANPT ID THREAD
    Hope someone can help me. I am trying to get a correct program to do an ID .500 anpt (same as npt) > I would like to do a G76 canned cycle but my post comes out totally wrong. any help would be great. The thread starts at z zero and ends at z-.690 max depth. Thanks for you help.
    May 2009
    63
    Forgot to add in the machine is a HAAS sl-20. Any help would be appericiated. Thanks again.
    Jul 2007
    195
    no brainer
    use a pipe tap.
    Be carefull what you wish for, you might get it.
    May 2009
    63
    Sorry can not use a pipe tap on a titanium aircraft part. If anyone is able to write up the canned cycle or just the G76 line to incorporate the angle I would be greatly appericiative.
    Jun 2010
    Below is an example of a 4 TPI thread with a 3 inch taper per foot.
    The “I” value is calculated by the radial amount from the target point to the finished diameter.
    On an OD thread this will usually be a negative value. On an ID thread this will usually be a positive value.
    In this case we start at Z.5
    TPF = 3.0 Length of thread in program =3.97
    TPF/2 = 1.5 Length of thread + dist to start posit = 4.47
    Solve for I
    12(I) = 4.47(1.5)
    12(I) = 6.705
    I = 6.705/12
    I = .55875
    I = .559
    N24 G55
    (THREAD O.D.)
    G00 T909
    M41
    G97 S250 M03
    G00 X8.898 Z0.5 M08
    M23
    G76 X8.268 Z-3.97 I-0.559 K0.14 D0.018 F0.5
    G00 Z3. M09
    G53 Z-13.78
    M01
    May 2009
    63
    Smile
    THANKS ALOT. THAT HELPED ME OUT. I CAN FIGURE IT OUT FROM HERE
  1. Thread spec for camera lens filter thread
    By cmays in forum MetalWork Discussion
    Last Post: 07-20-2016, 10:43 AM
  2. acme thread combos and thread mixing
    By calaber40 in forum Linear and Rotary Motion
    Last Post: 05-16-2009, 02:04 AM
  3. Thread mill external NPT thread
    By cutting edge in forum MetalWork Discussion
    Last Post: 09-15-2008, 02:33 PM
  4. M42 x 2 thread, first thread is sharp! Help...
    By Driftwood in forum MetalWork Discussion
    Last Post: 08-24-2008, 08:17 PM
  5. M42 x 2 thread, first thread is sharp!
    By Driftwood in forum Uncategorised MetalWorking Machines
    Last Post: 07-19-2008, 05:09 AM
