587,262 active members*
3,549 visitors online*
    Apr 2003
    98
    Multi Start acme Rod?
    Does anyone know if you can use the homemade tap trickin Delrin with a milti start (4start) acme rod
    RJ
    Learn from the mistakes of others you can't afford to make them all yourself!
    Jun 2005
    54
    Yes and No...
    I have cleaned/opened up ID acme threads using the OD threads of an acme screw.
    I used a bridgeport, and cut slots down the Acme screw (about 2-3 inches). This acts like a tap...
    I don't recommend doing it this way cause your major and minor of your thread will be incorrect, your delrin acme nut will be tight on the screw... but I guess it works in a pinch...
    (Acme threads are pretty easy, I do them almost every day) :-)
    It's a bit trickier, due to the higher lead, but it should work OK.
  1. Multi-start Thread on a Fanuc OT controller
    By Fudd in forum Uncategorised MetalWorking Machines
    Last Post: 09-18-2012, 06:35 AM
  2. How to multi part
    By Toddjones in forum Mastercam
    Last Post: 04-23-2009, 04:02 PM
  3. multi-boot two HDs
    By Karl_T in forum Computers / Desktops / Networking
    Last Post: 06-21-2005, 05:58 AM
  4. 1/2"-8 ACME 2 Start (4 turns per inch)
    By andy_ck87028 in forum Australia, New Zealand Club House
    Last Post: 04-04-2005, 03:44 AM
  5. Multi Speed Conversion
    By SPEEDRE in forum Benchtop Machines
    Last Post: 01-19-2004, 07:25 AM
