603,365 active members*
3,479 visitors online*
Results 1 to 8 of 8
    Jan 2009
    7
    CADmatic Holzma
    I have a few questions about CADMatic. As far as I know, if I want to send directly my cutting schemes to CADMatic version 3.0, I need to buy from Holzma a kind of buffer or protection software called Holzlink. The problem is that they charge a lot for it and I believe it is some kind of protection software that is not worth the price they charge. Does someone know how should I write my post processor and what extension the file should have, if I want to bypass CADMatic ? Does someone have an example ?
    Aug 2014
    Re: CADmatic Holzma
    I know this thread is incredibly old, but i'm currently trying to figure out the same exact thing. Anyone out there have any suggestions? I can create the cutting schemes on the one PC, but can't seem to find something that lets me use their weird file extension
    Oct 2014
    5
    Re: CADmatic Holzma
    I'm having the same problem. I have opticoupe to generate optimised cut plans, I have CADmatic 4 , but Holzlink is required. Not sure it worth the price as other manufacturer (selco) can directly import.
    I found this link that describe the .saw .ptx files:
    Holzma
    but i don't have time and knowledge to write a PP ...
    Oct 2014
    5
    Re: CADmatic Holzma
    Latest info from holzma:
    there are 2 solutions to convert schemes (in my case: coming from Opticoupe):
    1- Holzlink: approx 1700€
    2- CADLink: approx 1300€
    catalog prices without negociation
    Jun 2010
    51
    Re: CADmatic Holzma
    Hello,
    anyone can help saw file created with Cutrite 9 open in Cadmatic 3.0 ?
    Re: CADmatic Holzma
    The Astra R-Nesting software can do direct export to HOLZMA CadMatic4. Sample file attached. Extract this file from the ZIP archive and copy it to the folder: d:\Cadv40\Data\Runs
    Additional Holzlink or Cadlink modules are NOT required.
    Nov 2016
    5
    Re: CADmatic Holzma
    hello,
    reviving an old thread once again
    I contacted Astra-R and they charge 700$ for the post processor alone! and you have to buy the software. It seems a bit pricey just to be able to convert a cutting plan to a format that CadMatic 4.0 can understand.
    Is there a way to work around that? especially that there are android apps that can whip up an optimized cutting plan for a fraction of the price!
    Feb 2024
    4
    Re: CADmatic Holzma
    Cadlink, Holzlink(needed for Cadmatic 3-4), Cut Rite v11-12(needed for Cadmatic 5) for not a lot of money.
  1. PNC/PTX to CADmatic 3
    By Johzen in forum Uncategorised CAM Discussion
    Last Post: 10-28-2014, 01:17 PM
  2. CADmatic 2.5 user manual and online data transfer
    By Gorco in forum Uncategorised CAM Discussion
    Last Post: 06-09-2014, 12:57 AM
  3. HOLZMA CNC PANEL SAW
    By ptd in forum News Announcements
    Last Post: 07-29-2011, 02:16 PM
  4. CADmatic v3.0 Not deleting programs from depository
    By invin in forum Uncategorised CAD Discussion
    Last Post: 12-09-2010, 01:36 AM
