603,970 active members*
2,976 visitors online*
    Nov 2010
    16
    MasterCam V9 Mill Post processor
    Hi, I just bought a new HAAS VF-2D Vertical CNC Mill and don't have the post processor for MasterCam V9.
    This is my second CNC, the first is a Frank Pheonix PC based control for which I have the Mcam V9 Post for (came with the machine).
    I am using X2 MR2 as well but I just use the updatepost utility in X2 MR2 for my Pheonix Mill V9 post.
    I want to do the same with the HAAS CNC but don't know where to get the post.
    Is there a generic post processor that comes with Mastercam that will work for it? Or do I need to get the Post from somewhere else?
    Nov 2010
    I believe an mpfanuc post processor comes with MC9 and that should get you started. When I get to work I will grab my Haas VF-2 mpfanuc post processor and post it for you.
    Nov 2010
    16
    mpfanuc post....
    That would be much appreciated! thanks for the reply.. If you can include the .txt file aswell since mcam V9 uses it. I will then update the post in X2MR2 and be able to program using both versions... Thanks for your help.
    -Jack
    Jan 2011
    Similar Request
    We could use this for our mill as well, did you ever find it?
    Nov 2010
    16
    Mcam 9 post processor without the txt file
    here is the post I use that works great with the Haas.
    just use McamX or newer to update the post. You don't need the txt file usually assosiated with the Mcam 9 version .pst . just rename the .zip to a .pst
    -Jack
    Attached Files Attached Files
  1. mastercam x3 post processor
    By tomdbiggs in forum Milltronics
    Last Post: 07-13-2010, 02:33 PM
  2. Mastercam X2 post processor for X3
    By sotos in forum Syil Products
    Last Post: 07-03-2010, 07:24 AM
  3. MasterCAM X post processor
    By rodzilla in forum CNC Machining Centers
    Last Post: 05-08-2007, 11:09 PM
