588,182 active members*
4,215 visitors online*
    Apr 2005
    345
    V2XT switch wiring
    We just installed the new EMI software (SX upgrade) and put our pentium motherboard in and a new flat screen monitor.
    Now - there is a loose wire on the "spindle enable/start switch" about 2" long, looks like a jumper since it wont easily reach any other switches. Any of you know where this goes? Cant track it down from the schematics.
    We cannot get the machine to start a program, or start the spindle........probably due to this wire.
    Nov 2004
    3028
    I am guessing but there are two sides to this switch. The purpose being to enable the forward or reverse contactor (if you are in low or high gear). It is cost effective to run the power to one side of the switch and jumper it to the other side. Then there should be one return wire from EACH side of the switch. Therefore see which is the hot wire per a meter or the wiring diagram and that should be jumpered to power the other side.
    George
  1. Home?Limit Switch Wiring Diagram
    By Halfnutz in forum CNC Machine Related Electronics
    Last Post: 04-09-2005, 01:47 AM
  2. Surplus V2XT
    By matchlite in forum Bridgeport / Hardinge Mills
    Last Post: 03-30-2005, 01:07 AM
  3. Home limit switch wiring.
    By DAB_Design in forum Mach Software (ArtSoft software)
    Last Post: 12-23-2004, 12:48 PM
  4. Limit Switch / Home Switch in Software
    By Sanghera in forum CNC Machine Related Electronics
    Last Post: 11-02-2004, 12:58 AM
