I am making my first of what I hope will be many facemask molds. The product is a plastic air filled cushion/ I am cutting the mold from 6061 T6 using MasterCam X4 3D from SolidWorksmodels. This mask is shaped kind of like the seal on a CPAP mask It is about 0.700" wide at the top and about an 1.25" deep taper is 1 1/2 degree on each wall bottom is 0.38 wide.
The first two molds that I finished are not bad but can be better. I rough mill with a 3/8" Bull Mill with a 0.0313 radius and then finish mill with a 3/8" ball mill both are carbide 3 flute. I have some vertical lines that are evenlly spaced around the mold about 0.100" inch apart giving the walls a very small corrigated look. I can polish them out pretty quickly but would of course prefer not to have to do that.
I am open for any suggestions, thank you in advance.
Lowell
