586,065 active members*
4,385 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Need help with finding center of pinions.
Results 1 to 10 of 10
    Nov 2010
    I have a Sherline 5000 MANUAL mill, that I need to know how to find the center of an unbored pinion gear to bore a .198" hole. I thought you would find the edge first using an edge finder, but being that the pinion is round it would seem useless since after finding the edge I would still have to fiddle with the X and Y axis hand wheels to get the cutting bit to hit the exact center of the round pinion. So how do I go about doing this? I know the math way to find the center of circles obviously, but trying to adjust the dials on a mill in the real world is a whole different story.
    One other question I have is how do I properly secure this so that it is perfectly level to insure a straight hole?
    Aug 2009
    684
    You don't need to be perfectly on the circle centreline to find the centre. Just position the gear so that you can use an edgefinder/DTI to find centre in 1st axis (X), then move to the centre position in X and repeat the procedure to find centreline in 2nd axis (Y). Double-check the 1st axis. Done.
    The most accurate way to ensure the gear is sitting perpendicular to the spindle is to machine a fixture plate 'in situ' that will accept the gear and locate the appropriate face/diameter. Clamp over the part/fixture mating faces (ie don't clamp over 'fresh air') to eliminate clamp-induced distortion.
    DP
    Aug 2009
    684
    If you have the necessary tooling, a small DTI (Verdict T8 or similar) on a clocking-arm (bent piece of bar) is an easier and quicker way to find the centre. Saves the working-out if you don't have a digital read-out.
    DP
    Nov 2010
    a coaxial indcater would solve all your problems. on keeping it flat, if you have a machined surface on the gear. If you have alot of these items to build, make a fixture you can mill flat in the machine. then everything should be perfectly level with the spindle.
    Aug 2009
    684
    Assuming spindle is square to table
    DP
    Nov 2010
    If the head of your machine isn't tramed in, most likely all you will make on the machine is decoy anchors.
    Jul 2010
    369
    Do you have a combination square set? If so use the "center head"
    "crow's foot" or "center finder" whatever you want to call it.
    Scribe 2 lines at approx. 90 deg. from each other and poof you have center of the circle. Then just take a center punch and punch a spot put it in the mill with a center drill spotting drill and line up the work to the tool in the spindle.
    Its the fastest way but not the most accurate.
    Or you can use the dowel method where you put 2 dowels of the same dia. down in the teeth of the gear and indicate that. Its the most accurate way.
    Hope this helps.
    Good Luck~!
    Nov 2010
    I have been using the edge finder method, but now I would like to know how to use a Coaxial indicator to do the same. Can someone on here show a video or step by step pictures with explanation for using this tool to find the center of a circle?
    Aug 2005
    300
    Probably the most accurate way to find the center of a pinion would be to take 3 gage pins of the same diameter, place them approximately 120 degrees apart in 3 tooth space's and then tram around the OD of the pins. This will get you the closest to the center line of the pitch circle.
    Ernie
    Jul 2010
    369
    Here ya go.
    [nomedia="http://www.youtube.com/watch?v=ZfioLDhBNBQ"]YouTube - Tramming a mill with a coaxial indicator[/nomedia]
    Good Luck~!:cheers:
  1. Need help finding specs for DIN 332-D M12 center
    By mattslay in forum Uncategorised MetalWorking Machines
    Last Post: 10-16-2010, 06:37 PM
  2. Finding center of hole
    By georgebarr in forum Mach Mill
    Last Post: 10-08-2009, 12:27 PM
  3. finding center of a hole
    By BeerFizz in forum Mach Mill
    Last Post: 06-15-2007, 01:17 AM
  4. Finding the center
    By Tazzer in forum MetalWork Discussion
    Last Post: 08-05-2006, 06:18 PM
