603,785 active members*
17,864 visitors online*
Results 1 to 19 of 19
    Jul 2010
    Question 414 SERVO ALARM
    Help me please,
    My CNC is Fanuc 18M router machine.
    When i turn on power. The machine has an error 414 SERVO ALARM. X,Y,Z axis detect error. I think that is lower DC voltage.
    I see the led on main power is 02
    00 is ready
    -- is not ready
    ## is number code
    Can you help me? How is the 02 code?
    Jul 2010
    Smile
    I just check 24V DC power. I changed a new cooling fan. Number 02 alarm code become --. but on screen has a message "401 X,Y,Z,V,A SERVO VDF DETECT ERROR"
    Nov 2010
    cant remember what 414 is, but Fanuc have good maintenance manuals so you should find one for your machine and read it.
    Dec 2009
    1118
    check in electric cabinet the cables JS1A JS2A JS3A AND JS1B JS2B JS3B for bad contacts.
    u changed the cooler form upper side or from inside?\
    i think you have 1 also inside but i am not so sure and maybe u can check .
    I have this alarm 444: 4th axis detect error . My DGN for this alarmbis 723 bit 6 . Says LOW VOLTAGE. Somebody help me pleaseee
    Enviado desde mi GT-I9300 usando Tapatalk
    Jan 2013
    13
    I had a similar alarm on my Haas we replaced the vector drive and that solved the problem.
    Sent from my R800i using Tapatalk 2
    Aug 2007
    849
    Quote Originally Posted by dung_ninhbinh View Post
    Attachment 205076
    "2" low voltage
    if your drive is A06B-6066-Hxxx check circuit breaker inside the drive and of course all power connections (R, S, T)
    if incoming voltage is OK, then it's needed to check PCB inside the drive
    Ill try tomorrow changing the cables for DC link because the alarm is only for the 4th axys
    When i do turn to the motor i look in my position screen that B coordinates changing so the encoder its fine
    Aug 2007
    849
    the DC wires are too thick to be bad, besides you may measure DC voltage on incoming terminals L+ L-
    step 1: measure DC voltage. is it OK?
    no -> the fault is searched, think what to do further
    yes -> go to step 2
    step 2: swap control cables between axes. the fault moves to another axis?
    yes -> the drive or motor is faulty. think what to do further
    no -> the problem is not in drive. think what to do further
    tell what type of axis control card is being used?
    Fanuc service says the DC Link voltage must be between 370 to 400 VDC .
    My measure its 305 VDC
    Aug 2007
    849
    if your SVM has index "HV" his input DC is 600VDC
    if not - 300V
    Attachment 205144
    Attachment 205146
    Attachment 205148
    I think your DC is OK
    after all other drives work
    Yes me too
    Aug 2007
    849
    what type of axis card do you have?
    have you seen my posts with description of type A and type B cards?
    I mean type B
    Aug 2007
    849
    do you have circuit diagram of machine
    I am interested in list with servo to CNC connections
    there must be connectors labeled as JS.. JF..
    - - - Updated - - -
    we have to swap cables
    Yes PM me
    Sep 2013
    11
    sir,
    i have a bmc30 hurco machining center. in circuit relay board crp2 415-0224-003. 1 wire connection was shot in the right side of slot of wire. it was fell down during checking pls tell me the exact location 7 and 8 is empty and 11 and12 is empty where do i connect this wire?
  1. Replies: 2
    Last Post: 09-10-2018, 09:21 PM
  2. Replies: 6
    Last Post: 04-29-2011, 11:20 PM
  3. Alarm 409-servo alarm- z axis torque alm
    By jessebpm in forum Hyundai Kia
    Last Post: 06-15-2010, 01:45 AM
  4. 411 servo alarm, 6T
    By Jerry Shorter in forum Fanuc
    Last Post: 08-21-2009, 07:07 PM
  5. help me 400 servo alarm
    By club35bucuk in forum DNC Problems and Solutions
    Last Post: 07-16-2008, 06:33 PM
