586,804 active members*
6,821 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > Help me with some nice lathe tooling :)
Page 1 of 2 12
Results 1 to 20 of 39
    Jul 2006
    741
    Hi everyone,
    I think this might be my first post on this section of the site
    So... I'm getting a lathe now (chair)
    I have decided on the Grizzly G0709. It is a 14 X 40. Grizzly sells it as a "Gunsmith's Gearhead Lathe." It got some reasonable comments over the net. At some point in the future I might convert it to CNC, though an unknown amount of part swapping may need to take place. But that is probably a year away (famous last words).
    On the lathe itself, I'll be pulling the trigger tomorrow night.
    In the past I got my feet wet with CNC milling, but this is my first "lathing" experience. I'll be more careful with the lathe, so no crash videos on youtube this time
    So yes... the tooling...
    I like tools. One of my prized ones is an Albrecht chuck (R8). For what I do, home shop, I could manage with a generic import, but there is a certain pride and pleasure in owning and using tools of that quality. I do the roughing on my milling with US made Hanita clones. I like having a few higher end SGS end mills, etc, etc. Generally I do not buy "imports" tooling, though there have been exceptions.
    With that in mind I'm looking to spend about $200-$300 on new tooling and inserts to welcome my baby.
    It comes with a 200 series quick change tool post and a 1/2" MT#3 drill chuck. I already have (long story) a generic 7 piece set of indexable tools in 3/4" (product code 404-1054 from Shars). The 200 series post only takes up to 5/8", but I'll be getting a pair of extra tool holders and mill them down so that the 3/4" will fit. The tech support guy at Grizzly said that there is enough material in the holder for that. That is the extent of my tooling at this point. I do not have extra inserts or anything else. Well I do have a generic set of 3/4" boring bars, but these would not last very long if I really start to use them.
    I stopped by carbidedepot.com (where I get most of my end mills) and noticed that brand name holders start at about $50-60 and inserts at around $10. Did not check eBay, but I presume that if I knew what I wanted I might be able to get some stuff from there too. However, since I'm a total newbie I'm not even sure what shapes of holders/inserts would be likely to see the most use.
    • I know I probably would like a nice parting tool, but I'm not even sure if I should be going for a indexable tool for that, or sticking with plain HSS.
    • I probably would like a couple of "special occasion" tools/inserts that would give me the best finish I can get with the machine...
    • I do not know how much threading I'll be doing. Of the projects I have in mind threading does not play a big part. But threading is cool too.
    • I suppose a couple of smaller holders (1/2" ?) to get where the 3/4" can not.
    • I would also be turning some hot rolled, so I'm not sure what is the best strategy to handle the scaling as far as tooling goes.
    • I'm not big on grinding my own tools. I would rather use inserts unless we are talking very simple grinding.
    • I'm not sure if it is worth to spend on brand name inserts for that 3/4" set.
    So as you can see I'm a little bit lost. Yet I would like to welcome my lathe with a few nice tooling pieces.
    Ideas? Suggestions?
    BTW, I'll be turning mostly mild steel, some aluminum, and on occasion plastics and an odd piece of copper or two.
    Thanks!
    Jul 2006
    741
    Well, I placed the order for the lathe yesterday. But no additional tooling except for some HSS parting tools. I'll see what I'll do about the rest of the tooling later. Thanks.
    Nov 2003
    154
    I would recommend you get a set of toolholders which take the same insert, if possible. This will save a little money. Some sets also have a boring bar or two as part of a set. At least on I am thinking about is Micro 100. I know there has been a guy on ebay over the past few months selling individual holders and sets.
    You can go with either a positive or negative insert style with the 14" lathe, if you have a larger HP motor. If not I would stick with the positive types inserts (my personal preference but maybe not others).
    I would look at a C, D or T insert shape toolholder. Each type has different benefits. They can all reach into corners and still be used for facing. The W type inserts can also be very nice as they almost have an inherent wiping action to longitudinal cuts.
    You will not be able to buy one insert for cutting all metal types so expect to pay money for different types of metal cutting inserts.
    Another thing about insert is you may not be able to take full advantage of carbide and the differnt coatings because of your lathe speeds.
    I would read many of the information on carbidedepot.com reference section in depth and then read it again to understand some of the geometry and nomenclature of inserts. Carbide by itself will not enable you to lathe better. Buying dirt cheap inserts can sometimes cost you more in the end. Errors with carbide will cost you more than HSS.
    I would not go smaller than a 2 size radius for your lathe. I recommend that only because the insert tips will be stronger. The down side is you will not be able to get sharp inner corners. The larger radius may help (depending upon how you cut with it) with the surface finish.
    I would strongly recommend you learn to grind your tools. In some cases HSS may provide a better finish if used properly. Carbide is generally for production throughput. If you do not have to run part after part you may not see the benefit of carbide plus you do not have the higher speeds of CNC spindles.
    You can use either an inserted part off tool or HSS blade. Both can be finicky. The insert tool holder will be tend to be more expensive. No matter which way you go I would not go anything less than 3/32. Smaller than that can flex and break. I would learn the ins and outs of HSS but it is your choice.
    I would say you will easily reach $300 for tooling. Buy more quick change tool holders!
    Jul 2006
    741
    Thanks a lot for the tips MC.
    The main reason for carbide is so that I do not have to learn another skill -- have enough to keep extra busy without having to worry about grinding tools. So even if it is more expensive and offers no substantial benefits it is one less thing I have to worry about
    It has been taking me a few days to digest what you said and to do some research as well. It seems that tooling for lathes a bit more complicated than what I expected.
    So far I'm leaning towards WNxG to get my feet wet.
    With the "W" it seems that with just two holders (one left and one right) I could pretty much cut in any direction. So they would be really cool if I convert the machine to CNC later.
    With the "C" I'm not quite sure the 110* corner would be that useful and I would need 4 holders to use all 4 corners. I'm not sure I understand the "T" because it has the same number of usable corners as a "W" but it is sharper at 60*... so wouldn't that leaver a worse finish? Why are the "T"s so popular? Same with the "D"?
    I picked the xNxx as I read that the negative holder can also be used with positive inserts (but not the other way around). BTW, my motor is only 2HP. I hope I can do negatives.
    Then the xxxG would give me the double-sided use.
    For the shank I'm leaning towards 3/4". Even if I need to upgrade the tool changer later I think it is better to do that than to buy a bunch of new holders and end up with multiple sizes. Not that it plays in the decision, but in a pinch, that also allows me to use the 3/4 cheapish set I already have.
    For holding I'm thinking one of those pin and clamp systems.
    On the brand I'm leaning towards Kennametal because I find their literature and catalogs easier to understand. I simply can't figure out Iscar's.
    On the gauge 432 seems to offer more choices of inserts.
    On the different grades, I still have to research *sigh*
    So this is what I'm thinking about at this point...
    Inserts:
    Categories
    Holders:
    Product Detail
    Product Detail
    So yeah... a couple of holders and a few inserts and that is that.
    EDIT:
    After considering the grade I think I'm going with WMNG432MS which is uncoated. That way I can use it with ferrous and non ferrous. If they go by too fast, and I'm happy with the holders and insert shape then I could get another pair of holders to use with WMNG432RP which has one of those AlTiN-kind coatings that are good for steel. Weird that Kennametal would not offer a WMNG in a TiB2 coating or similar. (may be that is not the thing for lathes ?)
    EDIT 2:
    Yeap, even at 2000 RPM a 1" diameter only gets you to 500 sfm, but OTOH I have been running my mill at 400 sfm or less with carbide tools and, well, it works. Problem will be running it manually till the conversion.
    Jul 2006
    741
    Oh boy! The kennametal insert selection tool is getting me toltally different results. I guess it will take a couple of iterations
    Nov 2003
    154
    The tip radius has more to do with finish. The insert shape has to deal more with the inherent strength of the tip and insert. If the step over rate is larger than your tip radius you will get visible grooves in your part (like threads).
    I do not understand your quote "I picked the xNxx as I read that the negative holder can also be used with positive inserts (but not the other way around)." I have never heard that plus the geometry is not right. You can get a positive type cutting geometry in the negative insert. These special geometry inserts are normally ground and only used for nonferrous work, namely aluminum.
    It is the negative insert portion which gives you both sides of the insert. The last letter in the designation identifies the chipbreaker style and whether it is pressed on one side or two and the hole style.
    The MS in the insert identifies a specific chipbreaker style not the grade of insert. Chipbreaker styles will not be in all grades. Chipbreakers can range from finishing, roughing and general cuts and specialized to certain metals.
    If you are only worried about using all four corners on D and C inserts perhaps you should not get into carbide. My only hope is that you do not complain about carbide inserts after you invest money into them and do not see the results you are expecting.
    Jul 2006
    741
    Thanks for the clarifications MC
    Don't worry, grinding tools does not appeal to me. Not what I signed up for. I would rather get a bigger machine than having to grind my own tools. Which is something I'm considering since my g0709 is back ordered till December 17th. However, the next machine up which is single phase is double the price for 3HP and Meehanite casting. That would be the G9730. That is a big difference in price though.
    I'll work on the inserts again between tonight and tomorrow night.
    Jul 2006
    741
    I was thinking about some of this stuff on my way home and it is so much new information that is very easy to loose perspective. It turns out that the number of usable corners is not that relevant if you are only making a couple of hundred pieces a year.
    On the rake, it seems that you would want positive rake for non-ferrous and negative for interrupted cuts and steel, particularly if there is scaling.
    Let's see if i can work this thing out...
    Given the low fpm I have...
    Negative inserts for roughing steel -- style "MN", grade "KC9040" -- 300-700 sfm
    KennaPerfect Selection System :: Inserts for Steel
    Negative inserts for finishing steel -- style "FN", grade "KC9125" -- 450-900 sfm, but supposed to start at 600 sfm
    Add a geometry: Trigons WNMG-MN and WNMG-FN
    Now add the holder style: KENLOC
    In the turning catalog we only find WNMG-FN in KENLOC
    432 for a good size insert and relatively smooth radius ->WNMG432FN KC9125
    Found it at carbide depot, a bit on the expensive side at $10.47 a pop in sets of 10
    Product Detail
    Going back and trying to find a KENLOC -MN in 80* rhombic => CNMG-MN
    Yes, page A10 of the turning catalog!
    432 for a good size insert and relatively smooth radius ->CNMG432MN KC9040
    But... no KC9040 at carbide depot. Could order elsewhere, find something slightly different in KC9040 or go for KC9125 which carbide depot carries, but is NOT for interrupted cut.
    I think I got the mechanics (pardon the pun) and a bit of the nomenclature of insert selection... now if I only knew what I wanted :lol:
    One problem is that for non-ferrous the sfm are ridiculously high.
    Negative inserts for roughing non-ferrous KC5410 800-5000, supposed to start at 1800 sfm
    KennaPerfect Selection System :: Inserts for Non-Ferrous Materials
    Negative inserts for finishing non-ferrous KD100 1600-8000, supposed to start at 2500 sfm
    Did not find lower sfm that did not have an Al based coating... may be I'll look a bit further or call Kennametal when I'm set on the geometries.
    The extra quick change holders arrived...
    REALITY CHECK!
    They are small!!! The 200 series look like toys when compared with a 400 series holder *sigh* -- could still mill them down to hold 3/4" holders, but clearly a 5/8" shank would not be the weakest link in this set up.
    The advantage of the 3/4" holders is that (1) they would probably survive an upgrade to a bigger machine in a few years, and (2) there is a choice of holders taking a 432, negative rake, and a pin & clamp locking mechanism.
    Did not research much more, but 5/8" seems to limit your choices a bit more. At carbide depot where I found a variety of 5/8" was in the screwdown section for positive rake.
    Selecting end mills was so much easier
    Mar 2008
    443
    May I ask why you are focusing on getting a new Grizzly, and why only single phase?
    There's a lot of good used 3-phase lathes here in the northeast, and it's only abut $350 for a good VFC to convert single-phase power to 3. Where in NY are you? I might be able to help you find a very good machine and I know I can help with tool selection.
    I believe you're good to get WNMG style inserts and a holder for regular turning and facing. The holder would be something like an MWLNR 12-3. You'd be wasting money to get an MWLNL, because rare is the day you'd need to do "back turning" and never is the day you'd need back facing. You'd be better-off with a pair of MVJNR/MVJNL holders to take 35º profiling inserts to use for finishing and back turning.
    Those are just examples of tooling I might recommend. EVERYTHING depends upon what machine you get, what kind of toolpost it has and what kind of work you want to do with it.
    Geez, you were posting just as I wrote.
    You probably don't need such big inserts. An WNMG33x size insert would suit the smaller lathes just fine.
    Don't waste too much time trying to nail down grades. You will RARELY approach those speeds shown for the Kennametal inserts with an open bed toolroom lathe. The 25-30-35 range of carbide will serve you well despite no interuppted cut, because the tougher (vs. wear resistant) grades of carbide are better-suited to the low speed application of toolroom lathe work. Kennametal is far from the only good source, btw.
    What size lathe are you getting? This is what determines what size quick-change toolpost is best for your machine. A 12-15 inch swing should be using a CXA/300 size QCTP that can take up to 3/4" shanks. A 10-12" machine is better with a BXA/200 size for 5/8" tools. A 9" or smaller machine uses an AXA/100 size for 1/2" tools. If you buy a tool post system that's too big for the machine, you might not be able to lower the tools enough to get them on-center. Don't start buying tooling until you have the machine in place and ready to go!
    Jul 2006
    741
    Quote Originally Posted by PixMan View Post
    Thanks for the tips on the tooling! I need a few minutes to digest it. It is kinda overwhelming
    I'm actually in northern NJ. I moved a few years ago.
    The single phase is because I would otherwise need a phase converter. For a 5HP machine a 20HP converter sets me down a good $2K G7979 Rotary Phase Converter - 20 HP
    The new Grizzly is because I want to get up and running in a few days. The good oldies generally need a lot of work. As far as imports go the middle to higher end of the Grizzly line tends to be okay.
    Yeah... the quick change tool post that comes in this lathe is a bit lacking, being a series 200 and all. But then the machine is only 2HP and 1500 lbs. I mean that is probably the price point. Yes I would like a 5HP 2500 lbs machine, who wouldn't, but can't justify it right now cuz after you are all done you are going down for $13-15K and it is still a manual machine. With the one I selected I'll probably be at $5-7K depending on the tooling.
    But please let me know what you have in mind...
    Jul 2006
    741
    You too :lol:
    I picked the insert because I wanted to get 3/4" shanks. If I remember it right, most of the inserts I found were 432 and 332. So I just picked the 4 because it would give you a stronger insert. I could not see a big change in forces otherwise because we are only cutting with the tip. That is what i picked a 4 IC
    What is the "25-30-35 range" ?
    Yeah, I picked Kennametal because I managed to understand their catalogs/conventions, and they are easy to find. One vendor is very confusing already ... but no, I'm not married to it.
    It is a light 14x40 (1500 lbs) 2HP, cast iron. It already comes with BXA/200 and a live center. When I asked to upgrade to a 300 they said the only way to do that is to buy it separately. So I figure I would get an couple of extra 200 holders and mill 1/8 out to fit the 3/4" till the day i decide to get a 300 system... which would not have to be Grizzly BTW.
    Yeah... the tooling is a challenge.
    Technically I already bought the machine... that is the order is placed and the only reason why it is not in my basement is because it is back ordered till mid December for some reason. I presume I could cancel it as it has not shipped yet, but I think it is a pretty good choice at that price range.
    Mar 2008
    443
    I don't think you've spent enough time considering machines and are getting ahead of yourself with tooling. This Victor 1640 lathe, a 2500 lb 16x40 5HP, 3-phase lathe, is in my dad's shop for under $2000 with the DRO, Dorian CA QCTP, 10" chuck and 15HP phase converter.
    We made the phase converter for $350 for the American Rotary Power "box" a free 15HP motor that was kicking around when the company dad was working for got free motor upgrades to their AC system from the power company.
    You do NOT need a 20HP RPC for a 5 HP motor. Double the driven motor HP is more than enough. We went with 15HP because it was free. The deals are out there. You can also get by with a variable frequency drive. No RPC required and you get variable speed for your lathe. They run from about $350 to $700 depending upon quality and rating.
    I've added maybe $5000 worth of tooling and no parts to that lathe since the first month...for about $2000. When we got it, I spent $371 for a new cross slide screw & nut and a manual. The rest has been smart ebay and craigslist buys.
    As for inserts, you'll not have enough HP to bury a 332, so a 432 is just more money spent. What I mean by the 25-30-35 range is the last two digits of most modern insert nomenclature for grade. The numbers lower (10, 15, 20) tend to be the harder, more wear-resistant grades. The higher numbers represent tougher, more chipping-resistant grades that run at slightly slower speeds because they may wear more quickly.
    BTW, a friend of mine is using WNMG331 & 332 inserts in his Okuma LB15 CNC lathe, with 1" toolholders. Even with 20HP on tap, he's yet to break one of those "weak" inserts.
    Mar 2008
    443
    http://hartford.craigslist.org/tls/2067592018.html
    How far from Hartford are you? How much will the Grizzly cost when all is said & done with tooling and shipment? Get a lift gate cargo truck from Ryder for a day, go fetch this one and don't look back.
    The guy has several others too.
    Jul 2006
    741
    Looks like a very nice finding indeed. Congrats!
    I see where you are coming from, but I imagine that most of what is out there would require extensive work and some will never really hold tolerances. If you are in the business you know what to look for. And if you take your time, and with a bit of luck you have proven it is possible. But you and your dad are miles ahead of me.
    Even with guidance, perseverance and endless trips on Saturdays to warehouses it could take a year before something came up and then there is always the luck factor.
    A few years ago I got a forklift off Craig's list. I recently had a forklift mechanic take a look at it because that bad boy was leaking like an old man on Depends. He told me flat out I had paid too much for it. When I asked him how much I should have paid he just smiled... kinda like meaning... "the toll". The quote to fix it is $1,200 -- the hydro seals on the back wheels are gone. Anyway, as long as it lifts I can use it. I just have to keep a tray under it and put up with the streaks of oil wherever I drive it. With a lathe... it is not enough to turn.
    Let me digest the info you gave me on the inserts.
    Thanks!!!
    Jul 2006
    741
    About 3 hours with no traffic. You posted while I was typing, let me research a bit
    Jul 2004
    127
    Brazed Tools
    I have a 12x36 Grizzly and I've been quite happy with using those low cost carbide brazed tools that run around $4 each for the majority of my cutting. They initially come pretty much ready to go (unlike the HSS blanks) and when needed, can be sharpened on a bench grinder in 20 seconds. If you want to learn how to use a lathe, you're going to have to learn the basics of how to grind/resharpen tools at some point. Resharpening something that is already in approximately the correct shape skips the initially daunting task of starting with a square HSS blank. Need a better surface finish? Take a new one and put a slight radius on the tip edge via either a bench grinder or a diamond file. There are obviously a number of great insert cutters out there, but at ~50,75,100 a pop per holder finding one that works right with you could start to get expensive, especially if you're starting out. Plus you don't have to go through the size/style/alphabet soup of all of the inserts.
    The cut off tool is a different story. I initially started with a HSS cut off tool and absolutely hated it. I then found a carbide brazed cut off tool for $15 or so and it worked better, but still not that great (it had zero rake angle IIRC) I then decided to splurge for a $110 carbide cutoff tool + tool post and absolutely LOVE it. Parting off is now a joy to do rather than a pain. btw, I recently read a post that mentioned a lower cost grizzly brand insert cut off tool which he seemed to like.
    Hope this helps.
    -Matt
    Mar 2008
    443
    Quote Originally Posted by mc_n_g View Post
    I'll clarify. The insert strength is a function of both geometry and support. A thick negative rake insert has straight sides (90º edges) and most-often, a carbide seat to support it. A "positive rake" insert is single-sided with 5º, 7º, 11º or greater side clearance angle. Most use a single screw down the middle for fastening to the holder, and have no supporting carbide seat. These tend to be smaller I.C. sizes and are used on light-duty machines, light cuts on bigger machines, boring I.D.'s and other tasks. And to be clear:
    Tip radius (a.k.a. tool nose radius) together with feed rate and cutting action, is what determines a resulting surface finish. Feed rate is usually stated in inches or MM per revolution, is stated above as "stepover". That's a term more often used for width of cut for a milling cutter as it relates to width of the cutter.)
    Other factors in surface finish are tool center, lead angle, workpiece and tool rigidity, workpiece material, insert chipbreaker and edge prep, coating, and cutting speed.
    I use some "neg/pos" style inserts in stainless steels and high-temp alloys as well as aluminum, brass and other non-ferrous materials. An upsharp edge on a negative rake can be produced as peripherally-ground, or molded. The ground one will usually be sharper right at the cutting edge, but more fragile. Of course we don't rough out a piece of flame-cut HRS with a VNGP 330.5. One of the most common misconceptions is that the 3rd character of insert nomenclature, usually an "M" or a "G" means molded or ground. It doesn't. It's the character defining the tolerance limits of insert I.C. size, thickness and distance from I.C. to tip.
    Yup. The first alpha character is shape, the 2nd is side clearance angle or "rake" (but that's really a misnomer.) Any "N" would indicate the insert has 90º between the top and the side, and as long as it's a two-sided insert, you can flip it over. Some CNGP inserts I use are not double-sided. A CNMM would be another example, usually a callout for a very heavy-duty roughing insert.
    +1.
    It took me 30+ years to get to where I am in understanding carbide insert technology. (I'm a slow learner, apparently.) If I had the internet and good catalogs as a resource, I would have known all this stuff in much less time.
    Jul 2006
    741
    A quick update to the tool selection saga. After a lot of thought and consideration I decided to upgrade the lathe. The model I had bought was on backorder so the logistics were very simple. This one is also a 14x40, but 5 HP and 2500 lbs with meehanite casting. It is the G9732. It comes bare... I will have to select a quick change system.
    It shipped yesterday so I should be getting it Monday or Tuesday. It will probably take me another week to power it up because of moving it to its final location (uneven terrain to get to the basement) and get the phase converter (I ordered the wrong one).
    Well that is that for now. I'll try to recover from my comatose state after all the eating today and think tools tomorrow
    Happy Thanksgiving everyone!
    Jul 2006
    741
    I got a CXA Aloris tool post set. Since I got a lathe made in Taiwan I'm trying to get the tooling made in America (though I'm not sure there are any lathes made in America today anyway). Got a bunch of extra Aloris CXA-1 holders as well. The 15% off and free shipping from Enco on Cyber Monday came handy.
    They, Aloris, have the CXA-1S, but I'm standardizing on 3/4" as opposed to 1" -- at least for turning and facing.
    Did not get any inserts or holders yet. Gonna go slow on that as suggested. But will probably stick with Kennametal holders and inserts for the same reason. Will probably get them from carbide depot as I get very good service from them -- well if they have the specific items I select.
    Since quick change holders and tool holders last "forever" I think of the cost as being amortized over a long period of time. That, and the quality of the stuff, make it a worthy investment -- me thinks.
    The lathe arrives tomorrow.
    Quote Originally Posted by mcarvey View Post
    Hope this helps.
    -Matt
    Hi Matt,
    Thanks for the ideas. Plan A is still indexed tooling, but I will consider the brazed tools as you suggested. May be that will make things more manageable so that I can use indexed tooling for the more common/tougher tasks (removing scaling, interrupted cuts, and most turning and facing of steel) and brazed for the rest. That way may be I can limit the number of holders and insert types while still using those 80% of the time.
    I'll continue to research inserts and try to digest the info PixMan provided
    Lots of things going on though :drowning:
    Jun 2007
    73
    Ive had good results so far with the KennaUniversal grade inserts for our tool room lathes. Theyre spec'ed to work with just about any material.
    The catalog for them is online and the kennametal people cant seem to find an in print catalog that contains them .
Page 1 of 2 12
  1. Help with CNC Lathe tooling!!!
    By lfacio12 in forum Uncategorised MetalWorking Machines
    Last Post: 09-19-2010, 10:53 PM
  2. Tooling for Getting a nice finish in Wax
    By 8922uid in forum CNC Tooling
    Last Post: 08-26-2009, 07:43 PM
  3. Nice Ebay CNC lathe in MD.
    By LeeWay in forum Uncategorised MetalWorking Machines
    Last Post: 07-13-2009, 11:27 PM
  4. tooling for 10 X 22 lathe
    By mcundiff1 in forum Benchtop Machines
    Last Post: 03-09-2009, 04:15 AM
  5. Lathe tooling?
    By gearsoup in forum CNC Tooling
    Last Post: 09-21-2007, 06:52 PM
