586,983 active members*
2,991 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > Gecko 540 + Keling Power Supply + Keling Steppers - Good combo?
    Nov 2010
    Im looking at purchasing a gecko 540 controller, Keling Power Supply KL-600-48 48V/12.5A, and 4 Keling KL23H284-35-4B Steppers.
    Would this make a good combination? Is that an appropriate size power supply for both the controller and steppers?
    I will be using this for a cnc table that will both do plasma and aluminum milling.
    the 381s have the low inductance that is supposed to be a good match for the g540 plus 387s are out of stock
    Nov 2010
    Okay, thanks. After some reading/learning about inductance, those seem like a good idea.
    Can I get away with the smaller/cheaper 48v 7.3a running 4 steppers? 2 of them will be for dual driving the gantry. Any other power supply suggestions?
    Quote Originally Posted by metricmike View Post
    Probably could, the formula (from gecko) for gaging a power supply is to add all motor current
    then multiply by .6.
    (4)3.5 x .6 = 8.4 Amps.
    If you don't run 3D parts and only 2 axis move at the same time, you'd be under.
    I've run (3) 5 Amps motors simultaneously on the same 7.3A supply no trouble.
    Hoss
    http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
  1. Keling power supply
    By judleroy in forum CNC Machine Related Electronics
    Last Post: 04-19-2010, 04:36 AM
  2. Keling Power supply
    Last Post: 08-25-2009, 06:08 AM
  3. Gecko 540 Package from Keling. Good Choice or Not????
    By JeLC in forum DIY CNC Router Table Machines
    Last Post: 03-03-2009, 01:20 AM
  4. Gecko 540 Mach 3 Keling Steppers on a Taig
    By gunlocators in forum Gecko Drives
    Last Post: 02-21-2009, 09:58 AM
  5. Keling power supply?
    By mcruff in forum Automation Technology Products
    Last Post: 09-24-2007, 03:11 AM
