586,036 active members*
3,695 visitors online*
Results 1 to 6 of 6
    Jun 2005
    8
    Question Citizen A20 Type 6 or 7 ??
    We're looking at purchasing a Citizen A20 6 machine that is approx. 3 years old. Can anyone inform us as to what are the differences between a A20 6 to an A20 Type VII machine??
    304
    The A20 VI has no independant backworking tools. Your backwork is done with tools mounted in an endworking type station with the tool facing the subspindle. This works very well as long as your part cycle allows this without adding cycle time.
    The A20 VII does have 4 backworking tools mounted separate from the Gangblock thereby allowing you more freedom. You still have the added ability of using the gangmounted tool positions to work on the sub spindle. That would give you 8 possible positions for backwork, 4 independant and 4 shared.
    Either machine is a very well made and easy to learn machine.
    Good Luck!
    Jul 2009
    8
    A-20 VI is a 4 axis swiss-style machine. $1 side Z1, X1, Y1 (ID tool block attached to $1 side), & Z2.
    A2-20 VII is 5 axis swiss-style machine. $1 side Z1, X1, Y1 (with same ID block as VI), & X2,Z2 (with front mount ID tool post & backworking tool post).
    Simular to the layout of an L5-20 VII, without all the bells & whistles.
    Shadow
    Jan 2011
    44
    buy A32
    Aug 2010
    A20.6 have not produced, only A20.7
    cincom
    Jan 2008
    21
    get a a2-20 with the 30's tooling near the parts catcher, cycle times are greatly inproved over our a20 we have both in our shop and hands down a better machine because of the tooling layout
  1. CITIZEN L20 TYPE 8
    By chet470 in forum CNC Swiss Screw Machines
    Last Post: 07-01-2011, 04:04 AM
  2. Citizen FL-42
    By jayeff1 in forum Uncategorised MetalWorking Machines
    Last Post: 11-03-2010, 08:27 PM
  3. G71/G72 type I vs. type II cycles
    By sinha_nsit in forum Fanuc
    Last Post: 08-28-2010, 11:20 AM
  4. CITIZEN E32 6T
    By karantaba in forum CNC Swiss Screw Machines
    Last Post: 09-18-2009, 07:55 PM
  5. G71 type I and type II cycles
    Last Post: 11-03-2008, 12:34 PM
