586,655 active members*
2,671 visitors online*
    Nov 2010
    NB Linear System ??
    Does anyone know or have any experience with this type of linear motion?
    NB Linear Systems:TWA8UU 1/2" inch Ball Bushing:Block:Ball Bearings:VXB
    Dec 2009
    36
    Yes, I just finished my build using them, and they are awesome. No friction, smooth as silk. I had build a Solsylva CNC from the plans 3ft-4ft and used the roller skate bearings for the linear movement. It worked, but I had these linear bearing from another build so I kinda redesigned the gantry for the new build. I would use them again. I did a lot of research here on different tables and designs. I like Joe's CNC machines as well and think it would be a good build. I used the v-bearing on the y and z. I have 5 inches of travel on my z which is more than enough to cut the material, plus change out the bit. Hope this helps
    Attached Thumbnails Attached Thumbnails HPIM0478.jpg   HPIM0484.jpg   HPIM0475.jpg   HPIM0477.jpg
  1. linear rail system?
    By justin22885 in forum Joes CNC Model 2006
    Last Post: 02-24-2009, 03:54 PM
  2. Interesting Linear Drive System
    By TravisR100 in forum DIY CNC Router Table Machines
    Last Post: 01-17-2007, 06:01 PM
  3. 8 Foot linear guide system?
    By jkpugh in forum Linear and Rotary Motion
    Last Post: 12-11-2006, 01:38 AM
  4. new linear drive system
    By rceebuilder in forum Open Source CNC Machine Designs
    Last Post: 08-21-2006, 06:22 PM
