586,655 active members*
3,418 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Huanyang Chinese VFD settings and manual here!
Page 20 of 41 10181920212230
Results 381 to 400 of 808
  1. #381
    Re: Huanyang Chinese VFD settings and manual here!
    I have two of those spindles, clamped to a board for testing. On one of them, the bearings are noticeably tighter than the other. But they seem to run at similar temperatures.
    What I noticed, was the first time I ran them, they got pretty warm. But they seem to run cooler as they were ran more. The longest I have run them was maybe 20 minutes, and they probably didn't get much more than 100-110°F. But not running at 24,000.
    What was the ambient temp when you were running them? It was about 60-65°F in my garage when I was running mine.
    In practice, I will probably rarely run them over 18,000 rpm. And mostly in the 12,000-15,000 range. From what I've seen, I didn't think they would run that hot, but that perception may change when they are actually cutting.
  2. #382
    Apr 2005
    629
    Hi Gerry,
    The ambient was around 90 degrees F.
    The spindle was probably in the range of 160 just guessing. I found my infrared thermometer this morning so next weekend I will run the spindle again to see what temps it actually gets up to.
    Chris
  3. #383
    Mar 2014
    1131
    I need a little help here.
    I did the VFD parameter setup but the motor is like its surging at mid speed. It also shakes the machine badly. To listen the surge please watch the video below.
    Motor is brand new. Specs are:
    Phases: 3 Ph
    Number of Poles: 2
    Frequency: 50 Hz
    Max Amps: 8.2
    Rated Voltage: 220v
    VFD: Huanyang 4.0kw
    What I've tried:
    - Removed the pulley (Same result)
    - I've tried to control the motor through the operator panel (to make sure the analog signal of the BB is good)
    - I've measured the motor shaft with a dial indicator to see if the shaft is true. It's perfectly true.
    And this is my current setting (With the same order):
    This .xls table can be downloaded here: http://puu.sh/x1gzF.xlsx
    What can I do to solve this problem?
    Thanks in advance.
    Suat
  4. #384
    Mar 2014
    1131
    By the way,
    OK I checked this thread and I think I have to congratulate @mactec54 for being very patient all the time. He answered all the questions.
    I believe he also has already answered my question here: http://www.cnczone.com/forums/spindl...ml#post1768524
    But the motor mentioned in the post has 4 poles. Mine has 2 poles. For the working frequency how high can I go with the motor? 100hz?
  5. #385
    15362
    Quote Originally Posted by Azalin View Post
    By the way,
    If your motor is a good quality, then you can go as high as 120Hz, 100Hz would be safe if you are unsure of the motor quality, make sure you have a minimum Hz setting, this parameter is important, running the motor too slow, it will over heat without using an electric fan to keep it cool
    Both of these Parameters you set the same 20Hz may be as slow as you can go with this motor, you could try 15Hz
    PD011
    PD73
    These 4 Parameters would be set to the Max Frequency that you are going to run 100Hz or 120Hz max
    PD03
    PD04
    PD05
    PD72
    Mactec54
  6. #386
    Mar 2014
    1131
    Hi Mactec54,
    Got it.
    Say I use 100hz max, the parameter PD144 (I think it is the speed at 50hz) will be the value that is written in the motor plate (2900 in mine)? Or do I divide it to 2 (1450RPM)? EDIT: or double (5800)?
  7. #387
    15362
    Hi Mactec54,
    Got it.
    If the motor rated is 2900 @ 50Hz, then 100Hz would double the RPM but because the max number for this VFD would be PD144 3000, this then give it no restriction on the RPM
    Having 50Hz in your country your max for this motor would be 100Hz, so safe would be 80Hz with your 50Hz motor, if the quality is good then 100Hz will be fine
    The 120Hz I listed is for a 60Hz motor
    Mactec54
  8. #388
    Mar 2014
    1131
    Interesting. The manual I have the max value for PD144 is 24000.
    Sent from my MI 5s Plus using Tapatalk
  9. #389
    15362
    That's good they may have finally changed it, then try set it to the RPM that you expect to get with 100Hz
    This is what it has been for many years, there may be other changes that I have not seen, is there a number or anything on your manual or do you have a link to a PDF manual
    Mactec54
  10. #390
    Mar 2014
    1131
    I'll take a look to the manual if there is a change list.
  11. #391
    Mar 2014
    1131
    I've tried everything but no luck. The problem still persist. The motor surges at mid speed (700-1500 RPM) and shakes the machine. I've used the VFD it on my CNC-Router for 3 years without a single problem so I started to blame the motor (it's brand new ).
    By the way, my VFD is not new. I noticed the parameters don't reset at all after I set PD013 to 08. Then I googled and find a post that the author mentioned 01 instead 08. So tried 01 and it did the reset. Weird.
    The date I purchased the VFD is 07-16-2014 but I suspect it's much older than that.
    Please see the VFD name plate in the attachment.
    HY04D023B 220V 4.0KW General Variable Frequency Drive VFD Step-up Inverter $193.28 Free Shipping @GoodLuckBuy.com
    Maybe I should buy a better motor. Maybe a 4 pole one.
  12. #392
    Mar 2014
    1131
    By the way, I can not enter anything higher than 50 for PD003.
    This definitely is not my best day. I feel hopeless.
  13. #393
    15362
    Your VFD may be a copy of the Huanyang, which may be the reason for some different Parameter settings, there have been many different copies of this VFD, I don't think it is resetting correctly
    PD003 would of been set at 400 for your other spindle this is the main frequency that you would be running at
    PD000=0 if this is 1 then the VFD will not reset
    Your motor looks good, I would say there are some Parameters that have not reset to default
    Try everything set at 50Hz and see how the motor runs at it's standard name plate Hz
    Mactec54
  14. #394
    Mar 2014
    1131
    I checked this. It's 0.
    Tried this too. I also did a reset and touched nothing to see if the default settings would help but the result was same.
    Maybe the motor has not been balanced.
  15. #395
    Mar 2014
    1131
    When I set PD013 to 8 (or 1 on mine) does it reset everything or just some parameters?
  16. #396
    15362
    when you do a reset, after you enter the number, do you then press the Reset button, if it is working right it should reset the VFD's Default Parameters
    You could take your motor to a motor repair shop and get them to run it and see if it is the problem
    It also could be a frequency band that the motor does not like, what you do is you have to skip those frequencies that the motor does not like, I don't think skip frequency is available in these VFD Drives
    Look at PD006 try that at 20 or higher
    Mactec54
  17. #397
    Mar 2014
    1131
    I took the motor to a repair shop as you suggested. They were about to close the shop but the guy did a quick exam. The motor worked flawlessly. I was ready to buy a new motor if anything was gone wrong but it ran good. Then I brought it back to home and continued my trials. I then wanted to try another torque curve. I tried one of the high torque curve and it worked perfect.
  18. #398
    15362
    So you used the PD006
    You can use PD145 also, which is for auto Torque Compensation, this helps with the PD006 settings
    Adjust PD041 Carrier Frequency do this in small steps, this parameter will make the motor run smoother and with less frequency noise, 8 to 10 can be normal for this Parameter, look for Heating of the VFD and Motor, when adjusting this Parameter
    Mactec54
  19. #399
    Mar 2014
    1131
    Hi again,
    Motor runs fine for a short time then starting to shake. The best I could achieve is by using the high torque curve (the lower right curve on the attached image). I also played with Carrier Frequency for smoother run but nothing changed.
    I also have a Siemens Sinamics V20 3kw inverter that I'm using for my cnc router. I'll pull it out and make a test with the motor. If it runs fine then I'll buy another Sinamics. If not then I'll buy a 6 pole 1000 RPM motor. But I think the working duty of the motor must be S3 for the job. The motor I have is S1 rated which means "start once, run for long periods".
  20. #400
    Mar 2014
    1131
    By the way mactec54,
    The manual that came with my Huanyang as a parameter set for frequency skipping. It allows you to setup multiple frequency ranges. I don't remember the parameter numbers but let me know if you want them.
  1. Replies: 6
    Last Post: 05-04-2024, 04:05 PM
  2. Car hoist 3phase settings on huanyang vfd
    By pietskiet in forum Spindles / VFD
    Last Post: 10-21-2019, 10:04 AM
  3. Huanyang SL-240EE Manual (SL Series Manual for Vector VFD)
    By Cogolith in forum Phase Converters
    Last Post: 05-24-2016, 04:19 AM
  4. Huanyang inverter PD settings
    By jamriggsy in forum Phase Converters
    Last Post: 03-15-2013, 04:54 PM
  5. Huanyang 2.2kw VFD, 0-10v 3600rpm settings?
    By EmeraldIsleforg in forum Phase Converters
    Last Post: 09-23-2012, 03:00 PM
