586,655 active members*
3,194 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Huanyang Chinese VFD settings and manual here!
Page 33 of 41 233132333435
Results 641 to 660 of 808
  1. #641
    Feb 2012
    43
    Re: Huanyang Chinese VFD settings and manual here!
    No worries lol, you've got to be running around here helping at least 5 people at a time so I sure don't expect you to remember everything
    The VFD I have isn't the Hy, it's the YL620-A clone I guess. There's an area near the wiring that calls out poles for a braking resistor so I thought I'd check. I asked the hy seller on Amazon if they had an idea but no response yet.
    To bring my spindle up to 24k do I need to update p03? I don't think it's getting adequate cooling as it runs since it's air cooled. The minimum they're calling for is 8,000rpm
  2. #642
    15362
    Quote Originally Posted by SpyderHelix View Post
    Yes it does say optional for the Breaking Resistor, you might be lucky with that
    I will give you some up dates no P03 is the stopping mode
    So your Breaking Resistor would connect to the +D and B- Terminals
    The minimum speed is P00.09=150 change that to 150 and see how it goes I have some others to change also which may help with the heat
    Mactec54
  3. #643
    Feb 2012
    43
    Ok awesome, thank you very much for the help!!
  4. #644
    Feb 2012
    43
    Hey mactec, been having to put my machine on pause while I am doing flooring but got it set up this afternoon.
    Question.. Does this sound like 24k rpm to you? I'm comparing it to other spindles I've seen on YouTube and it seems almost gutless..
    I'm also not getting much air out of the business end onto the spoilboard.
    My spindle:
    https://youtu.be/Q0PvzPj6wD0
    Comparison spindle:
    https://youtu.be/NVmpJxHIUmM
    Any help appreciated. I used the parameters that you gave me a page or so ago, only chanting those you have me.
    Thank you!
  5. #645
    15362
    Hey mactec, been having to put my machine on pause while I am doing flooring but got it goes up this afternoon.
    Thank you!
    Yes it sounds like it is at max RPM, you can change the acceleration this will help with getting it up to speed a little faster
    They don't have a lot of air flow the important thing it to check the temperature
    Mactec54
  6. #646
    Feb 2012
    43
    Awesome, thank you sir!
    Looks like I'll finally get to make chips tomorrow - I really appreciate the patience and the help, thank you
  7. #647
    Apr 2005
    23
    Got a new VFD Huanyang for a 2hp motor.
    I am trying to program it but there is no PROG button. Only SET, The 4 jog keys, Start, stop/reset.
    So I press SET and it does go into the prog mode it seems. But the letters say Pn and not Pd and I am only able to enter 2 digit number for the function. I need to get to Pd141-4 to set up the motor but only able to get two digits.
    Model A2 8022M
    The manual even refers to pushing the PGRM button but there is no such button on this one..
  8. #648
    15362
    Quote Originally Posted by minitech cnc View Post
    Model A2 8022M
    Can you post a photo of the VFD Drive Terminal Block it sounds like you have a copy of the Huanyang which may be an AskPower or one of the many other copies
    The programing is quite different if this is the case
    Mactec54
  9. #649
    Apr 2005
    23
    Trying to get pics to work. Can tag and upload but close the window and they are gone.
    I used to use photobucket but they started to change to a pay site.
  10. #650
    Apr 2005
    23
    The manual that came with it looks like the Huanyang from my other one.
    I’ll keep trying to get pics to work
    Here it is on eBay though and it has pics of it
    https://www.ebay.com/itm/2-2KW-3HP-S...53.m2749.l2649
  11. #651
    15362
    The blue label is the give away it is not a Huanyang that is for sure unless it is there GT model which does not appear to be
    Mactec54
  12. #652
    Apr 2005
    23
    Looks like the model number on the unit is in the right place but not a Huanyang number, they start with HY and this is AT
    Could it be a Huanyang but a lot/model made for some other company like Bust Buy would with some things, their own model number so they can advertise lowest price or will beat any price but all the model numbers are theirs?
    What can I do now with it?
  13. #653
    15362
    When I return to the USA I will be able to help you with it, 26th They use the HY even though it is a copy not sure why Huanyang have aloud these copies to do this, they are nothing to do with Huanyang VFD Drive company what's so ever
    Mactec54
  14. #654
    ericks Guest
    As long as you have a manual for it, they easy to set up
  15. #655
    No I have more than 60 different VFD Drive manuals so have that Drive on file
    Here are the Parameters that should get you going
    Mactec54
    Huajiang VFD Drive
    YL 600/620 110v/120v 1.5Kw Water Cooled
    P00.00=400
    P00.01=0
    P00.04=400
    P00.05=400
    P00.06=110%
    P00.07=140
    P00.08=35%
    P00.09=120
    P00.10=30%
    P01.04=110
    P03.08=120
    P03.09=400
    P06.00=0
    P06.01=8 ( Acceleration Adjustable )
    P06.02=8 ( Deceleration Adjustable )
    P07.00=400
    P07.08=0
    P11.01=110
    P11.02=7
    P11.03=400
    P12.00=7 ( Spindle Rated Amps )
    P12.01=110
    P12.02=2
    P12.03=5
    P12.05=14 ( VFD Drive Rated output Amperage )
    P12.06=110
    Hi Mactec54.. im pretty new to this. Im hoping these settings will work for my 2.2kw air cooled spindle aswell. It seems some of the vfd settings are hard to figure out. Im running a 220v vfd..but the nomenclature is in p.00 format. Any chance you can send me to a post where yhis has been discussed already?
  16. #656
    15362
    Quote Originally Posted by Terryble24 View Post
    The P00 format means nothing if you have a different VFD Drive what is the model number of the VFD Drive
    Mactec54
  17. #657
    Its the yl620-a..
  18. #658
    15362
    Its the yl620-a..
    Just the spindle Amps Drive amps and Voltage that would be different from the above Parameters
    Mactec54
  19. #659
    Anyone know of a way to piggyback these vfd's. I'm wanting to mount 4 spindles on my machine and run them all simultaneously. It would sure help if they all turn on with a master.
  20. #660
    15362
    Quote Originally Posted by sticky1970 View Post
    What VFD Drive do you have and yes it should be not problem to turn them all on at the same time, could be as simple as one Relay, I guess you are running at a set speed so that could be where there could be problems if you want to control the speeds, if you can set the speed in the drive and just auto turn on then that is quite simple to do
    Mactec54
  1. Replies: 6
    Last Post: 05-04-2024, 04:05 PM
  2. Car hoist 3phase settings on huanyang vfd
    By pietskiet in forum Spindles / VFD
    Last Post: 10-21-2019, 10:04 AM
  3. Huanyang SL-240EE Manual (SL Series Manual for Vector VFD)
    By Cogolith in forum Phase Converters
    Last Post: 05-24-2016, 04:19 AM
  4. Huanyang inverter PD settings
    By jamriggsy in forum Phase Converters
    Last Post: 03-15-2013, 04:54 PM
  5. Huanyang 2.2kw VFD, 0-10v 3600rpm settings?
    By EmeraldIsleforg in forum Phase Converters
    Last Post: 09-23-2012, 03:00 PM
