586,062 active members*
4,548 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > Bridgeport / Hardinge Mills > Bridgeport Series II Interact 2 -- how to remove top plate above spindle
    Oct 2006
    181
    Question Bridgeport Series II Interact 2 -- how to remove top plate above spindle
    I would like to temporarily remove a round plate that holds the top bearing right above the spindle.
    Does anyone know how it is mounted and if there is any trick to its removal. I tried to remove it gently and it did not work. It seems to be mounted by three 1/4"-20 socket head cap screws and I believ e may also be used to install a power drawbar.
    The reason for this is that I want to install an encoder on the spindle. So, if anyone knows of a good way to do so, PLEASE let me know. Thanks
    Thanks, guys!
    i
    1121
    standard cnc vari speed right? should be those three bolts as I recall. no leverage to pull it up. are there more through threaded holes to use as pushers? god, just did the belt 2 months ago and already forgot
    Sep 2007
    69
    Gus has it ....remove the bolts that hold the plate. Install same bolts into the alternate threaded holes and use them to JACK the top plate up and off.......do it evenly.
    Oct 2006
    181
    Everything worked out GREAT!
    I was doing it to install a spindle encoder, to allow myself to do rigid tapping.
    It is all done and over with, here's the web page about this:
    Bridgeport Series II Interact 2 CNC Mill ==> Spindle Encoder
  1. Spindle encoder on Bridgeport Series II Interact 2 mill
    By ichudov in forum Bridgeport / Hardinge Mills
    Last Post: 08-11-2010, 07:00 PM
  2. Top spindle I.D. on a Bridgeport Series II Interact 2
    Last Post: 08-11-2010, 01:49 PM
  3. Bridgeport Series II Interact 4 Spindle Brake
    By UKRobotics in forum Bridgeport / Hardinge Mills
    Last Post: 04-27-2009, 06:22 PM
  4. BRIDGEPORT SERIES 1 INTERACT SPINDLE REPLACEMENT INSTRUCTIONS
    By RMARCH in forum Bridgeport / Hardinge Mills
    Last Post: 03-09-2008, 10:04 PM
  5. Identifying Bridgeport Series 2 Interact 4 Spindle Motor
    Last Post: 05-26-2006, 12:55 PM
