588,548 active members*
5,774 visitors online*
    Jan 2006
    123
    4'x9' Dual purpose router build
    Hello everyone I have been lurking in these forums now for a few years and have just finished a CNC conversion of my CT29N mill (http://www.cnczone.com/forums/bencht...onversion.html). I am currently in the design phase of my CNC Router build and am at the point where I need to run a few things by the experts before I finalize my drawings. I had a 4'x4' ShopBot for a few years in my workshop but do to a move I no longer have it. Since I have the shop space now I am looking to add a second CNC machine to the workshop. This new machine will have a 4'x9' cutting surface for the router and down the road I hope to be able to run a plasma torch with a water table. The water table is going to be built into one end of the table and be sealed up and covered over when not in use. I don't plan on going with the plasma setup right now as I need the machine to make some money to pay for the plasma cutter.
    My current plans are calling for a rack a pinion setup using a rail system similar to the one CarveOne is using on his mills. For the motors and electronics I am looking at running the following:
    - NEMA 34 HIGH TORQUE STEPPER MOTOR 640 oz-in
    - KL34H280-45-4A (1/2" Single Shaft)
    - Gecko G201X drivers
    - Unregulated Power Supply 1440W, 72VDC/20A
    - C11G - Multifunction CNC Board
    The larger 640oz-in steppers are a little over kill for the Y and maybe Z axis but I like the compact size and the gantry is going to be fairly heavy as I am planning on run a dual Z axis setup (drilling on one side router on the other).
    I was planning on running a PC router but I am wondering if anyone has any experience on the spindle Keling is offering.
    KL-2200 Milling Spindle
    Specification
    OD=80 mm x 215 mm Voltage: 220V
    Speed: 8000-24000 R/min
    Power: 2200 W (3HP), Frequency: 400 Hz
    Water Cooling, ER20 collet chuck
    Grease Lubrication, NSK Bearing, Runout off: less than
    0.005mm
    Water cooling about 20-26 gal/hr
    KL-VFD22
    Specifications
    LED Display
    Input: 220V 50/60Hz, Single Phase
    Output: 0-240V 2.2Kw (3HP) 11A
    Frequency Range: 0.1-400Hz
    0-10V Analog interface capability
    Variable speed potentiometer
    1 year limited warranty
    It seems to be able to a fairly able setup and it would be in the ball park of a decent router setup.
    Build is going to be all steel for the framing and gantry and aluminum for the motor mounts and most of the Z-axis. I almost have the table designed in CAD and will share the drawings once I get them ready. I need to finalize the stepper choice as I plan on mounting them under the table for space savings.
    Any comments are more than welcome.
    Apr 2007
    8082
    Sounds like an ambitious build coming up. I'll be watching.
    CarveOne
    CarveOne
    http://www.carveonecncwoodcraft.com
    May 2010
    307
    I will be watching as well. I love the idea of multitasking machinery.
    Jan 2006
    123
    I would love to have two separate tables but my work space won't allow for it. I am still working on my drawings and hope to get some more time to work on them next week when I am out of town for work. Has anyone had any experience with the spindles I mentioned. I am really leaning that way.
  1. tuning dual servos on CNC router
    By Boltz in forum Servo Motors / Drives
    Last Post: 05-16-2023, 02:50 PM
  2. Richster's Solsylva dual leadscrew build
    By Richster in forum DIY CNC Router Table Machines
    Last Post: 04-28-2013, 04:52 AM
  3. Dual router Heads on a 2006?
    By Jmtwo in forum Joes CNC Model 2006
    Last Post: 04-28-2010, 07:27 PM
  4. Advice on Dual Plasma Router Table
    By Mini-MillX2 in forum Waterjet General Topics
    Last Post: 01-27-2007, 12:04 PM
  5. dual purpose cnc router
    By junkmail in forum DIY CNC Router Table Machines
    Last Post: 03-10-2004, 07:01 PM
