603,836 active members*
2,646 visitors online*
Results 1 to 6 of 6
    Dec 2007
    159
    Spindle Motor Bearings
    I have an Arrow 1000 and the spindle motor is starting to make a lot of noise.
    I am assuming it is the bearings.My question is can I take this motor to a local shop and have it repaired or do I need to send this to a specialized repair facility? I thank you in advance for your answers and suggestions.
    Scott
    Jul 2010
    369
    I had a noise coming from my Cin. and I thought it was the bearings turned out to be some hydraulic lines where clattering together. ON another Cin. I did have the spindle bearings go out and I replaced them myself not a hard task Just time consuming. Id check for anything loose before I tear into it.
    Good Luck~!
    Sep 2009
    45
    What about the belts?
    Dec 2007
    159
    I got back up on the machine this morning and for once I think I lucked out.
    I haven't put a scope on it but it seems to me that the noise is actually coming from the fan. I'll tear into it this afternoon and see what I got.
    Thanks guys.
    Dec 2007
    159
    Fan
    Lucked out it was the fan! While working on this machine another went down
    anybody got a power supply for an 850sx?
    Thanks to all,
    Scott
    Jul 2010
    369
    Thats good news about the fan!
    Always check for the simple stuff :idea:
    I know of a guy that replaced his entire spindle...was a 2 month downtime just to start up the machine and it made the same exact noise...turnned out to be some loose sheet metal.....(nuts)
  1. Spindle motor bearings?
    By smittys800 in forum Fadal
    Last Post: 08-08-2009, 06:07 PM
  2. spindle bearings
    By robinhood2b in forum Bridgeport / Hardinge Mills
    Last Post: 06-10-2009, 10:03 PM
  3. Lathe spindle bearings and spindle material
    By mackeym in forum Uncategorised MetalWorking Machines
    Last Post: 08-21-2007, 08:49 PM
  4. Lathe spindle bearings and spindle material
    By mackeym in forum Linear and Rotary Motion
    Last Post: 08-11-2007, 04:53 PM
  5. Spindle bearings
    By Hood in forum Bridgeport / Hardinge Mills
    Last Post: 11-22-2006, 02:36 AM
