603,354 active members*
3,054 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Polishing Aluminum using Burr King Vibra King 40
    Apr 2008
    11
    Hey guys, I do alot of aluminum cutting...mainly 1016 aluminum or mic 6 plate. I have a burr king vibra king 40 that i use to de burr parts in, but i ordered some corn cob and walnut shells because I read that you can polish parts in the machine using that media. Right now, time isn't a issue - i've read it can take up to 10 hours. Anybody have any pointers before I give it a shot?
    Thanks for your time
    Dec 2010
    (Aluminum) Plastic media works real good to remove Burrs,
    with flow thur water and soap.
    then corn cob with ruse the white for finishing DRY (i spelled wrong?)
    or wheat, walnut shell, all with metal polish DRY (works for stainless steel also)
    get some 5 Star metal polish in the can (2 pints?) it works great. Pink
    owner operator
    mike
    Dec 2010
    Quote Originally Posted by 07vistabluegt View Post
    12 hours for small machine and my 2.5 cubic foot is <1 hour
    rule: bigger machine bigger media fast cutting grit = fastest
    its all about the pressure on part to cutter(media)
    and always rinse after use or the media will "Glaze"
    and settle in tank making life crappy.
    Apr 2008
    11
    I have a few more questions...Should I do this in a process?
    Example.
    Take the part out of the machine, and use the media to de-burr the part in the vibraking. Then take out the media that "de-burr's" and put in the walnut/corn cob shells and let it do its thing?
    Dec 2010
    Example.
    Unless you have 2 machines.
    Its a lot of in/out, with one machine.
    some people try to "mix" the media, and screw up the whole process.
  1. Manual King Mill to CNC
    By cfcmach in forum Vertical Mill, Lathe Project Log
    Last Post: 02-22-2008, 11:28 PM
  2. Need DIY flow through system for Burr King
    By mp- in forum Mass finishing equipment/media/strategies
    Last Post: 11-20-2007, 09:05 PM
  3. King 10x22
    By 2Gs in forum Mini Lathe
    Last Post: 07-28-2004, 03:56 AM
  4. King of Posters !
    By HomeCNC in forum Community Club House
    Last Post: 02-02-2004, 07:19 PM
