586,075 active members*
4,325 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > Reversing Tapping head vs Tension/Compression tapping Head
    Nov 2007
    151
    I have never used a tapping head... been taping manually but am thinking about getting one soon. What are the differences between the reversing and tension/Compression tapping heads? Pros and Cons? Which is easier to use? Price seems to be pretty much the same. Thanks!
    Ken
    Jul 2009
    7
    Hi Ken,
    I have a tension compression tapping head and the main difference is speed. You can tap a lot faster with the reversing tapping head so if you have a lot of holes to tap the reversing head might be a better choice. The tension compression head requires some simple programming but it is not a big deal. The reversing head also requires a torque arm to prevent the head from spinning. Not a big deal either but something to consider.
    Len
    Sep 2008
    325
    The reversing head can also be used on a drill press or manual mill if need be.
    Feb 2008
    154
    I had the same question and after reading on the internet, I believe the tapping head is more forgiving for blind holes thanks to the clutch. So you are less likely to break the cutter due to inprecise rpm or slow acceleration of the spindle. I got a used one a few weeks ago off ebay for less than $100. I tried it manualy on my drill press and it works great.
    Jul 2007
    1602
    There was a good discussion of various tapping options in this thread: http://www.cnczone.com/forums/tormac...c_tapping.html
    bob
  1. Tapping with the Tormach Tapping Head
    By bobs_charger in forum Tormach Personal CNC Mill
    Last Post: 04-24-2009, 10:08 PM
  2. Tension & Compression tapping
    By cnc steve in forum MetalWork Discussion
    Last Post: 04-04-2009, 11:10 AM
  3. Tapping head or rigid tapping
    By Gregory_C in forum Syil Products
    Last Post: 10-18-2008, 06:49 AM
  4. Rigid tapping or tapping head
    By kentavv in forum Charter Oak Automation Support Forum
    Last Post: 09-24-2006, 06:08 PM
  5. tapping head vs hand/cordless tapping machine....
    By InspirationTool in forum Uncategorised MetalWorking Machines
    Last Post: 09-13-2005, 02:10 AM
