586,082 active members*
3,807 visitors online*
    Jun 2009
    110
    Import DXF files directly into Mach 3???
    How the heck does one Import a simple scribe outline line for a wing into Mach 3 directly. I milled a mold for a DLG glider which is fine but now want to make a tool change and V-tool scribe the trailing edge of the wing. I'm running Vectric Cut 3D which will not see the line because it's not 3D. I looked in the Mach 3 manual and it says to look in the file menu for direct DXF import but I do not see it. It's a simple poly line so it should work. Any help out there???????????????
    The .dxf importer is long gone. You need to use LazyCAM, which replaced it, or a 2D CAM program.
  1. Import/Export Files between Rottler P69 and F68A
    By soporte in forum Uncategorised CAM Discussion
    Last Post: 07-04-2010, 11:12 PM
  2. How to import ProE files in Solidworks
    By Tony888 in forum Solidworks
    Last Post: 07-03-2009, 05:05 AM
  3. Import/Convert DXF or PLT files to Mach3....
    By Mikael in forum Mach Mill
    Last Post: 12-25-2008, 10:33 AM
  4. mach 2 import image
    By gilligan in forum Machine Created Art
    Last Post: 11-23-2006, 12:22 AM
  5. VBA - Import & Split large files
    By NeoMoses in forum Visual Basic
    Last Post: 11-12-2006, 09:38 PM
