603,923 active members*
4,837 visitors online*
Results 1 to 6 of 6
    Jul 2009
    96
    i give up NEED HELP
    i just got a nm-145 this is my first cnc machine and i dont want to blow another couple thousand dollars on a quick change system just yet. is their any way to execute a tool change using collets and have the part come out right? in other words can i re zero the Z in the middle of a program during a tool change?
    35494
    Something like this?
    [nomedia="http://www.youtube.com/watch?v=7np99wSr9c8"]YouTube - Mach3 2010 Auto-Zero[/nomedia]
    Jul 2009
    96
    not quite. say i have a .75x.75x1" peice of aluminum and i want to machine a dome on top of it. my first set of code calls for a 1/2" roughing end mill to get the rough shape. my finishing step is using a 1/4" ball end mill. i dont have end mill holders or a quick change tool set i have to change the tool by removing the collet and end mill and replacing it with another. inside the collet their is nothing to set the tool height just a regular R8 collet. in this case can i during the stop for the tool change some way rezero for this tool.
    35494
    Yes, that's what I'm doing in the video. It's a macro that zero's the initial tool to the workpiece, and also gets the location of a reference plate. After changing the tool, the new tool uses the reference plate to get the same zero position as the original tool.
    http://www.cnczone.com/forums/mach_w...r_big-tex.html
    Jul 2009
    96
    thanks ill look again. this is all pretty new to me.
    Aug 2005
    302
    Z height control
    Go to Tormach's web site Home | Tormach | We provide personal small CNC machines, CNC tooling, and many more CNC items and look at their TTS line of tool holders. These have a shoulder that butts up against the bottom of the spindle so that the tool locates in the Z plane almost exactly each time you change tools.
    Ernie
  1. Please give your thoughts
    By Dolphin USA in forum Dolphin CAD/CAM
    Last Post: 06-29-2010, 11:33 PM
